Certbot autorenew and renew fails
server-demo.wematch.live
sudo certbot renew --nginx --dry-run
and also this one
cd /etc/letsencrypt/ && ./certbot-auto renew --dry-run --nginx
my certbot-auto script is in the letsencrypt dir
Requesting to rerun ./certbot-auto with root privileges...
Processing /etc/letsencrypt/renewal/server-demo.wematch.live.conf
http-01 challenge for server-demo.wematch.live
nginx: [warn] conflicting server name "" on 0.0.0.0:80, ignored
nginx: [warn] conflicting server name "server-demo.wematch.live" on 0.0.0.0:443, ignored
Attempting to renew cert (server-demo.wematch.live) from /etc/letsencrypt/renewal/server-demo.wematch.live.conf produced an unexpected error: Failed authorization procedure. server-demo.wematch.live (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: Fetching http://server-demo.wematch.live/.well-known/acme-challenge/BN9xKygmKkZv-qVxEGajtEv9XqsjJYwrTJVye8F3LB0: Timeout during connect (likely firewall problem). Skipping.
/etc/letsencrypt/live/server-demo.wematch.live/fullchain.pem (failure)
    Domain: server-demo.wematch.live
    Type: connection
    Detail: Fetching
running on NGINX 1.10.3
Ubuntu 16.04.1 x64
i configured my DNS records on cloudflare
Installed: 0.28.0-1+ubuntu16.04.1+certbot+4
Hi @Eitan
if you want to use http-01 challenge, an open port 80 is required. But your port 80 doesn't answer ( https://check-your-website.server-daten.de/?q=server-demo.wematch.live ):
|Domainname|Http-Status|redirect|Sec.|G|
|• http://server-demo.wematch.live/
67.207.68.227|-14||10.026|T|
|Timeout - The operation has timed out|
|• https://server-demo.wematch.live/
67.207.68.227|401||2.050|M|
|Unauthorized|
|• http://server-demo.wematch.live/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
67.207.68.227|-14||10.027|T|
Is there a firewall or something else?
And your configuration is buggy:
You have the same server name in different blocks. Then Certbot doesn't know which of these is used.
there is a security mechanism that we implement on our level, that is why it is unauthorized.
do i need to open port 80 in the firewall setting for it to work ?
The 401 on your / isn't relevant to create a new certificate. Letsencrypt doesn't check the main page.
If you want to use http-01 - validation: Yes.
But you can add a redirect http -> https, Letsencrypt follows this redirect.
It's a good configuration having (1) an open port 80 and (2) correct redirects http -> https, then one redirect from the non-preferred version to the preferred version.
So in the end, there is no content visible under http (only redirects) and every user has (after some redirects) the same https - url.
PS: I saw, you have rechecked your domain.
The 401 fetching a file in /.well-known/acme-challenge is critical.
So Letsencrypt can't validate the file Certbot has created.
yes, i have made some changes.
i think there is another issue i encounter now, when i add the following like to the crontab to automatically renew the certificate every interval, it is not getting renewed.
but when i run it manually it works.
25 * * * * cd /etc/letsencrypt/ && ./certbot-auto renew --nginx --force-renew && /bin/systemctl restart nginx
i saw the in syslog that it ran the command, but there was no renew
You should NEVER add --force-renew to a cronjob! Let certbot decide if it’s time to update or not.
Also, with just “it is not getting renewed” and without any other information, we can’t give you any advice. At least you should post the certbot logs for the attempt.
You have a new certificate
CN=server-demo.wematch.live
	02.02.2019
	03.05.2019
	server-demo.wematch.live - 1 entry
So use this certificate 2 months, then check, if the renew works.
i know, but i wanted to test whether the crontab works or not.
this was only for the purpose of testing the renewall
There is an entire staging environment for testing.
