Renew cert Max retries exceeded with url: /directory
My domain is: plimsoftware.pt
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/www.plimsoftware.pt.conf
Attempting to renew cert (www.plimsoftware.pt) from /etc/letsencrypt/renewal/www.plimsoftware.pt.conf produced an unexpected error: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<urllib3.connection.VerifiedHTTPSConnection object at 0x7f3e1216b2b0>: Failed to establish a new connection: [Errno -3] Temporary failure in name resolution',)). Skipping.
My web server is (include version): nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.4 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 0.27.0
Anybody can help? Thanks!
This suggests to me that the DNS resolving capabilities on your server are broken. Can you test that by running host acme-v02.api.letsencrypt.org please?
I have my site in a VM on Google Cloud Platform. Running host acme-v02.api.letsencrypt.org i have the following: ;; connection timed out; no servers could be reached.
Same result with host google.com
That means your VMs DNS resolving doesn't work in general and it's is not related to Let's Encrypt.
I resolved doing
sudo systemctl restart systemd-resolved.service
:grinning: :grinning:
I'd recommend checking sudo apt-get update to see if there are some updates to install as systemd-resolved should be pretty hard to crash, normally.
