Max retries exceeded with url: /directory
My domain is: malerjakt-admin.no
I ran this command: sudo /usr/bin/certbot renew (This run daily with crontab)
Processing /etc/letsencrypt/renewal/malerjakt-admin.no.conf
Attempting to renew cert from /etc/letsencrypt/renewal/malerjakt-admin.no.conf produced an unexpected error: HTTPSConnectionPool(host='acme-v01.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by NewConnectionError('<requests.packages.urllib3.connection.VerifiedHTTPSConnection object at 0x7f266c93bad0>: Failed to establish a new connection: [Errno -2] Name or service not known',)). Skipping.
/etc/letsencrypt/live/malerjakt-admin.no/fullchain.pem (failure)
My web server: nginx/1.10.0 (Ubuntu)
The operating system: Ubuntu 16.04 xenial
My hosting provider: hetzner.com
I can login to a root shell: yes
I'm using a control panel: no
The version of my client is: certbot 0.10.2
ACMEv1 is fully deprecated and all certificates issued with that version of the API have expired and cannot be renewed using that endpoint. The Let's Encrypt team is continuing to deprecate the service and it is no longer returning an error message.
If you've been attempting to use ACMEv1 your logs would previously include a link to this thread and the included error message:
This thread and many others on the forum can help you upgrade your clients to use ACMEv2 and issue a new certificate.
