Error when renewing cert: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:1131)')))
My domain is: websitesbynihal.com
Processing /etc/letsencrypt/renewal/websitesbynihal.com.conf
Failed to renew certificate websitesbynihal.com with error: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by SSLError(SSLEOFError(8, 'EOF occurred in violation of protocol (_ssl.c:1131)')))
/etc/letsencrypt/live/websitesbynihal.com/fullchain.pem (failure)
NodeJS v12.22.5
Debian GNU/Linux 11 (bullseye) [Raspberry Pi 4]
N/A
Yes
No
certbot 1.27.0
Looks like https://letsdebug.net/websitesbynihal.com/1548974 is showing inaccessible Port 80, which is needed for the HTTP-01 challenge.
Can you test outbound connections for us? What do these show?
curl -I https://acme-v02.api.letsencrypt.org/directory
curl -I https://google.com
curl -I https://acme-v02.api.letsencrypt.org/directory:
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to acme-v02.api.letsencrypt.org:443
curl -I https://google.com:
curl: (35) OpenSSL SSL_connect: SSL_ERROR_SYSCALL in connection to google.com:443
Looks like you have some general problem with outbound connections.
Get those working first and try getting the cert once that is fixed.
Is IPv6 enabled?
Yes, it is.
It seems to be a general issue that my pi can't access the internet, but can access my local network. Thanks for setting me down the right path!
I'd start by fixing, or disabling, or deprioritize, IPv6.
Try these:
curl -I6 https://google.com
curl -I4 https://google.com
With the I6 flag I got this:
curl: (7) Couldn't connect to server
Whereas with the I4 flag I got this, like before:
That's worse that I expected.
IPv6 fails hard.
And IPv4 isn't much better.
What shows?:
openssl version
OpenSSL 1.1.1n 15 Mar 2022
Show the output of:
openssl s_client -connect www.google.com:443
[then press ctrl-c to breakout of that]
CONNECTED(00000003)                                     write:errno=0
---                                                     no peer certificate available                           ---                                                     No client certificate CA names sent
SSL handshake has read 0 bytes and written 306 bytes
Verification: OK
---                                                     New, (NONE), Cipher is (NONE)
Compression: NONE                                       Expansion: NONE
No ALPN negotiated                                      Early data was not sent
Verify return code: 0 (ok)
There should have been a lot more output.
Like:
CONNECTED(000001FC)
depth=2 C = US, O = Google Trust Services LLC, CN = GTS Root R1
verify error:num=20:unable to get local issuer certificate
Certificate chain
 0 s:/CN=www.google.com
   i:/C=US/O=Google Trust Services LLC/CN=GTS CA 1C3
 1 s:/C=US/O=Google Trust Services LLC/CN=GTS CA 1C3
   i:/C=US/O=Google Trust Services LLC/CN=GTS Root R1
 2 s:/C=US/O=Google Trust Services LLC/CN=GTS Root R1
   i:/C=BE/O=GlobalSign nv-sa/OU=Root CA/CN=GlobalSign Root CA
Server certificate
-----BEGIN CERTIFICATE-----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-----END CERTIFICATE-----
subject=/CN=www.google.com
issuer=/C=US/O=Google Trust Services LLC/CN=GTS CA 1C3
Peer signing digest: SHA256
Server Temp Key: X25519, 253 bits
SSL handshake has read 4875 bytes and written 261 bytes
Verification error: unable to get local issuer certificate
New, TLSv1.2, Cipher is ECDHE-RSA-CHACHA20-POLY1305
Server public key is 2048 bit
Secure Renegotiation IS supported
Compression: NONE
Expansion: NONE
No ALPN negotiated
SSL-Session:
    Protocol  : TLSv1.2
    Cipher    : ECDHE-RSA-CHACHA20-POLY1305
    Session-ID: 92CF9F6C28BE96281101285177F4AE9AA988043A870409987F1787110D516682
    Session-ID-ctx:
    Master-Key: 0A955EA71DDC7382C5BE2A5987B01D7359DD430AC60F3B249366C3F96DD2E04B67C47BA6250F8AB9B0198042C0B0817A
    PSK identity: None
    PSK identity hint: None
    SRP username: None
    TLS session ticket lifetime hint: 100800 (seconds)
    TLS session ticket:
    0000 - 02 b5 b8 30 00 14 2c be-01 77 e4 2d ff b2 95 9b   ...0..,..w.-....
    0010 - 3c 47 3b cc b7 89 17 65-21 b6 0e 2c 74 1e 47 59   <G;....e!..,t.GY
    0020 - f1 d5 62 c2 7a 91 0d a2-2d 2b 9f 72 96 56 b1 31   ..b.z...-+.r.V.1
    0030 - c7 b4 ea 0b 50 12 ad 60-66 3a 0c 37 75 ca 2e f0   ....P..`f:.7u...
    0040 - 1e d8 b7 54 8f e4 9d 03-26 6a a4 13 05 0a 29 6d   ...T....&j....)m
    0050 - 42 69 5a 8d 5b b4 96 bf-44 50 bb 85 b5 49 67 06   BiZ.[...DP...Ig.
    0060 - 98 20 e0 5e f4 67 97 94-63 de ce 90 ba 35 50 b6   . .^.g..c....5P.
    0070 - eb b1 49 d4 69 48 af 4a-61 bb a7 7b 80 70 c7 35   ..I.iH.Ja..{.p.5
    0080 - 93 71 5f 5c 01 6a 7f 8b-ef 75 2e 35 91 9c 07 0e   .q_\.j...u.5....
    0090 - eb 72 eb f8 53 08 36 a2-3d b8 f8 b0 28 d9 60 5a   .r..S.6.=...(.`Z
    00a0 - e6 0b cd 14 90 06 89 17-53 b5 94 bb 20 3f 58 cf   ........S... ?X.
    00b0 - d6 3e 03 ca 1a 33 71 4b-29 62 9c 8d db 53 c7 6f   .>...3qK)b...S.o
    00c0 - a4 71 3d 91 27 b7 3a e0-ef 3d 8e 2b 27 7f 91 4e   .q=.'.:..=.+'..N
    00d0 - db b9 46 22 3e 74 e8 f5-6b ba 4d 49 41 c8 37 52   ..F">t..k.MIA.7R
    00e0 - 23 6c 4f 02 11                                    #lO..
    Start Time: 1689293038
    Timeout   : 7200 (sec)
    Verify return code: 20 (unable to get local issuer certificate)
    Extended master secret: yes
^C
CONNECTED(00000003)
write:errno=0
Verification: OK
Compression: NONE
Expansion: NONE
No ALPN negotiated
I don't know what to tell you, I ran it again and it did the same thing it looks like
It seems like there is a "man-in-the-middle".
Try connecting to your own server's IP:
openssl s_client -connect 192.168.0.0:443
[use your actual IP]
results with local IP:
548518980096:error:0200206F:system library:connect:Connection refused:../crypto/bio/b_sock2.c:110:
548518980096:error:2008A067:BIO routines:BIO_connect:connect error:../crypto/bio/b_sock2.c:111:
connect:errno=111
The web server is up by the way; the page loads from my desktop.
I meant use the actual IP of the web server.
Oh, OK. Here that is:
CONNECTED(00000003)
Can't use SSL_get_servername
verify return:1
depth=1 C = US, O = Let's Encrypt, CN = R3
verify return:1
depth=0 CN = websitesbynihal.com
verify error:num=10:certificate has expired
notAfter=Aug 26 00:09:56 2022 GMT
verify return:1
verify return:1
Certificate chain
 0 s:CN = websitesbynihal.com
 2 s:C = US, O = Internet Security Research Group, CN = ISRG Root X1
   i:O = Digital Signature Trust Co., CN = DST Root CA X3
Server certificate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subject=CN = websitesbynihal.com
issuer=C = US, O = Let's Encrypt, CN = R3
Peer signature type: RSA-PSS
SSL handshake has read 4607 bytes and written 363 bytes
Verification error: certificate has expired
New, TLSv1.3, Cipher is TLS_AES_256_GCM_SHA384
Compression: NONE
Expansion: NONE
No ALPN negotiated
Verify return code: 10 (certificate has expired)
Post-Handshake New Session Ticket arrived:
SSL-Session:
    Protocol  : TLSv1.3
    Cipher    : TLS_AES_256_GCM_SHA384
    Session-ID: 28511565F0AA07489A7D929D0BC18AAEB80448D8FA7188AA78FCFAE726251ACD
    Session-ID-ctx:
    Resumption PSK: 1D39BA86A8771CE702F1A0D0D9EFE061A58FB86B9E1E5B651A54137E1F7AA2D7952F444F39B126343A5ABB9B575B0903
    PSK identity: None
    SRP username: None
    TLS session ticket lifetime hint: 7200 (seconds)
    TLS session ticket:
    0000 - 68 25 e5 46 e5 88 c4 37-54 63 47 2a 3e bd bb d6   h%.F...7TcG*>...
    0010 - 4c f6 11 d5 ee 4c f4 4f-9f ac 4f 93 c5 51 bf b9   L....L.O..O..Q..
    0020 - e9 75 f5 df 9b f2 bf c9-74 91 8b a8 24 5c 0a ce   .u......t...$\..
    0030 - ef f4 60 76 4c a4 56 59-c9 45 75 7f 23 a0 9f ae   ..`vL.VY.Eu.#...
    0040 - dd 48 d9 24 97 15 d7 be-b1 a5 e3 24 6f a0 ba 8e   .H.$.......$o...
    0050 - 0f a3 00 33 dc 62 71 7a-67 53 96 2f c3 b8 2d 10   ...3.bqzgS./..-.
    0060 - aa 8d b4 3c ca 1c 6e 1e-cd 3f 34 5d b5 02 ba 5e   ...<..n..?4]...^
    0070 - c8 a1 a0 dd 84 04 a7 07-0c 96 32 e4 dc da 53 b4   ..........2...S.
    0080 - c5 fb cf 5b ce df fa da-dd de 25 c0 89 a3 9f 2a   ...[......%....*
    0090 - 27 75 2e 62 81 0f d6 75-81 ce 00 36 52 23 bd ce   'u.b...u...6R#..
    00a0 - f4 1a 69 df 20 e5 74 24-67 48 d2 5f b9 9a c1 58   ..i. .t$gH._...X
    00b0 - 85 87 af e7 00 fd 91 57-f2 ae be a1 c4 27 f6 24   .......W.....'.$
    00c0 - b2 26 93 bd 43 70 0e c7-d6 ff c1 e6 4b f0 38 56   .&..Cp......K.8V
    00d0 - bb a1 c3 8d db ba ff 3f-87 04 92 1d 5f a5 ac a7   .......?...._...
    Start Time: 1689296344
    Extended master secret: no
    Max Early Data: 0
read R BLOCK
SSL-Session:
    Protocol  : TLSv1.3
    Session-ID: 0A88301CBBAD0014EA3AB5D64BAF4D0251DD5D414EC5846F46AC6DFB2F8671C2
    Session-ID-ctx:
    Resumption PSK: 6B4D1AE1EE3FB3171FA2E4D28DDF9C445DE70BA9D06973289D43257F42A5292D4B6F50EF1D0625E7B2CC0DE1BB5537CF
    PSK identity: None
    SRP username: None
    TLS session ticket:
    0010 - 63 14 07 85 75 b1 9b e7-02 58 64 c2 e2 ec 68 64   c...u....Xd...hd
    0020 - ff 04 5f d4 fe f6 37 0d-97 e2 19 b9 f3 b3 9d ea   .._...7.........
    0030 - 32 8f 1f 47 86 ed ce 4d-db 8a b2 4b 0e f8 4f 85   2..G...M...K..O.
    0040 - 30 5b 65 f8 ac 4b ed 63-ac 1a da 63 56 61 86 2b   0[e..K.c...cVa.+
    0050 - 01 bf b8 fe 2c 3a 03 cd-37 2e b0 6f df 90 db e4   ....,:..7..o....
    0060 - 52 68 ff 37 44 a1 9f 1b-fb 1e d3 17 df fe eb 4b   Rh.7D..........K
    0070 - 5c 51 9e f7 80 b3 b1 58-2f d0 59 50 1a d3 e8 f1   \Q.....X/.YP....
    0080 - 37 d9 3a 81 33 c5 6b 05-a8 0d 71 62 53 9e 28 79   7.:.3.k...qbS.(y
    0090 - 1e b0 81 fc a5 d4 12 cb-7d 03 91 d1 36 cd 27 9b   ........}...6.'.
    00a0 - a6 ac c3 d7 7c c6 52 c8-42 cb 29 9f a2 0f d3 5d   ....|.R.B.)....]
    00b0 - 27 ea ad 3e 65 52 73 83-6e 90 5b 2e 74 c6 15 2a   '..>eRs.n.[.t..*
    00c0 - 89 5e e1 ef c1 ce 57 8f-cb 73 8c 4b be d4 6c cf   .^....W..s.K..l.
    00d0 - a7 31 8a 9a e8 31 24 83-4b 0b 60 56 86 1e 7c 81   .1...1$.K.`V..|.
    Max Early Data: 0
read R BLOCK
