Max retries exceeded with url: /directory
My domain is: anamazingwizard.com
I ran this command: certbot certonly --webroot --webroot-path /usr/share/nginx/html/react --dry-run -d anamazingwizard.com
It produced this output: https://pastebin.com/2Nqqs74B
My web server is (include version): nginx latest
The operating system my web server runs on is (include version): ubuntu 18.04
My hosting provider, if applicable, is: hostinger
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot vesrsion: 2.0.0
i am trying to get certificate using certbot but whatever i do or change i still can not get successfull certificate response .What is weird i get it done in the same way in my different app on the same host, but different server a year ago and its working without issues until today, so i do not know it there was some change i am missing. App is build on django with react, nginx, certbot using dockerfile and docker compose.
When i am trying to get a certificate in a dry run i get an error that i linked above.
curl -v https://acme-v02.api.letsencrypt.org/directory gives me this output: https://pastebin.com/ef1FheGH
nslookup acme-v02.api.letsencrypt.org output:
https://pastebin.com/wGFPN4BR
traceroute acme-v02.api.letsencrypt.org output:
https://pastebin.com/JV0WJ6v1
If someone could help me solve this issue it would be great because i am out of ideas.
The title of your post says "Max retries exceeded with url: /directory"
But, I don't see that in any info you showed. Normally that message appears when you make too many failed attempts to request a cert. But, you show you are using the staging system which is very tolerant of failures. It is very unlikely to get a "max retries" failure for that.
What I do see in your log is this error:
socket.gaierror: [Errno -3] Try again
Which google says relates to a temp failure in DNS lookup.
I don't have any specific ideas but wanted to clarify the "max retries" message. Can you explain where you see that message?
this error message can be found in the first link i posted, line 51
Thanks. The cause is the same errno -3 which looks like a DNS lookup problem.
When you run those test curl, nslookup or traceroute are they also in that same docker as you are running certbot?
Because my guess is something is wrong in your docker for DNS.
Hi, all commands are from the same docker.
I have decided to run on my other server which works correctly this command in my certbot container:
and i got other issue which maybe creates the main problem:
Simulating a certificate request for anamazingwizard.com
http-01 challenge for anamazingwizard.com
Using the webroot path /usr/share/nginx/html/react for all unmatched domains.
Challenge failed for domain anamazingwizard.com
Domain: anamazingwizard.com
Detail: 191.96.53.227: Invalid response from http://anamazingwizard.com/.well-known/acme-challenge/8B8ZBuCXyj9LJKMUjfilMqzZHZBMS-RJIoVeijWzwlM: 404
Full log can be found here: https://pastebin.com/byT1ubij
From other topic with the same problem you suggested to try something like this
mkdir -p /usr/share/nginx/html/react/.well-known/acme-challenge/
echo "Test_File-1234" > /usr/share/nginx/html/react/.well-known/acme-challenge/Test_File-1234
From both
http://anamazingwizard.com/.well-known/acme-challenge/Test_File-1234
http://www.anamazingwizard.com/.well-known/acme-challenge/Test_File-1234
it downloads the file
What exactly should i double check that might resolve my problem?
This is what I get; doesn't seem to have properly created and served .well-known/acme-challenge/8B8ZBuCXyj9LJKMUjfilMqzZHZBMS-RJIoVeijWzwlM
$ curl -I http://anamazingwizard.com/.well-known/acme-challenge/8B8ZBuCXyj9LJKMUjfilMqzZHZBMS-RJIoVeijWzwlM
HTTP/1.1 404 Not Found
Server: nginx
Date: Fri, 16 Dec 2022 19:08:58 GMT
Content-Type: text/html; charset=utf-8
Content-Length: 146
Connection: close
Vary: Accept-Encoding
Using this online tool Redirect Checker | Check your Statuscode 301 vs 302
> 404 Not Found
|**Status:**|404 Not Found|
|**Code:**|404|
|**Server:**|nginx|
|**Date:**|Fri, 16 Dec 2022 19:12:28 GMT|
|**Content-Type:**|text/html; charset=utf-8|
|**Content-Length:**|146|
|**Connection:**|close|
|**Vary:**|Accept-Encoding|
Seems like http (Port 80) redirection to https (Port 443) does not exist.
The HTTP-01 Challenge is on Port 80.
Also using this online tool https://check-host.net/ yields Connection refused for https://anamazingwizard.com all around the world.
Using this online tool TCP Port Scanner, Online Port Scan, Port Scanning | IPVoid Scan all common ports using IPv4 Address of 191.96.53.227
443 TCP Closed https
$ nmap anamazingwizard.com
Starting Nmap 7.80 ( https://nmap.org ) at 2022-12-16 19:29 UTC
Nmap scan report for anamazingwizard.com (191.96.53.227)
Host is up (0.16s latency).
Not shown: 995 filtered ports
PORT     STATE  SERVICE
22/tcp   open   ssh
80/tcp   open   http
443/tcp  closed https
5432/tcp open   postgresql
8000/tcp open   http-alt
Nmap done: 1 IP address (1 host up) scanned in 10.29 seconds
oh sorry they shoud be both http at the beginning, https is not working yet, i edited post
But alone http nginx conf should be enought to get a certificate
My nginx config https://pastebin.com/kbi2QwU0
This is what curl is showing me for http Port 80
$ curl -I http://anamazingwizard.com/.well-known/acme-challenge/Test_File-1234
HTTP/1.1 200 OK
Server: nginx
Date: Fri, 16 Dec 2022 19:33:12 GMT
Content-Type: application/octet-stream
Content-Length: 15
Last-Modified: Fri, 16 Dec 2022 18:42:55 GMT
Connection: close
ETag: "639cbc2f-f"
Accept-Ranges: bytes
$ curl http://anamazingwizard.com/.well-known/acme-challenge/Test_File-1234
Test_File-1234
ye, that seems fine to me but why when certbot is doing challenge gets 404
What does ls -l /<path to proper location>/.well-known/acme-challenge/ show you?
Owner, permissions, is the file present, etc.
Share the output if you are comfortable doing so and that is is not sharing anything that should stay private.
Who is the owner for nginx?
Who is running certbot?
Did you sudo for certbot?
I am grabbing at straws here with ownership and permissions of the .well-known/acme-challenge/ directory.
It should work from everything you've posted. I'd be curious to see if there's anything in the nginx error log.
You could try use the nginx authenticator as well:
certbot certonly -a nginx --http-01-port 8080 \
-d anamazingwizard.com -d www.anamazingwizard.com --dry-run
[sorry if this was stated earlier]
How does the port 80 request reach the service on port 8080?
Is there a NAT or proxy "helping"?
I typed this command on nginx container and the output is
-rw-r--r-- 1 root root 15 Dec 16 18:42 Test_File-1234
i cannot run this command on certbot container
Can you run any commands in the certbot container?
How are the containers "interconnected"?
i am running certbot certonly command in certbot container
my docker compose is as follows:
version: '3.9'
services:
  backend:
    restart: always
    build:
      context: .
      dockerfile: Dockerfile
    command: bash -c "python manage.py migrate && python manage.py collectstatic --noinput && gunicorn project.wsgi:application --bind 0.0.0.0:8000 --workers 5 --reload"
    volumes:
      - .:/anamazingwizard
      - media:/anamazingwizard/public/uploads
      - apps_static:/anamazingwizard/apps_static
    ports:
      - "8000:8000"
    depends_on:
      - db
  frontend:
    restart: always
    build:
      context: ./frontend
    volumes:
      - react_build:/react/build
  db:
    image: postgres:13-alpine
    ports:
      - "5432:5432"
    volumes:
      - db:/var/lib/postgresql/data
    env_file:
      - .env
  nginx:
    restart: always
    image: nginx:latest
    build:
      context: ./nginx_prod
    volumes:
      - react_build:/usr/share/nginx/html/react
      - apps_static:/usr/share/nginx/html/react/django_static
      - certbot-etc:/etc/nginx/ssl/
    ports:
      - "80:8080"
      - "443:443"
    depends_on:
      - backend
      - frontend
    command: "/bin/sh -c 'while :; do sleep 6h & wait $${!}; nginx -s reload; done & nginx -g \"daemon off;\"'"
  certbot:
    image: certbot/certbot
    container_name: certbot
    volumes:
      - certbot-etc:/etc/letsencrypt
    entrypoint: "/bin/sh -c 'trap exit TERM; while :; do certbot renew; sleep 12h & wait $${!}; done;'"
volumes:
  certbot-etc:
  react_build:
  media:
  db:
  apps_static:
I don't see anything obviously wrong with that docker compose .
Why can't you run the command @_az showed?
What certbot certonly command are you running?
