Max retries exceeded with url: /directory
My domain is: ama-test.clarity-tec.com
I ran this command: docker-compose run --rm --entrypoint "
certbot certonly --webroot -w /var/www/certbot
$staging_arg
$email_arg
$domain_args
--rsa-key-size $rsa_key_size
--agree-tos
--force-renewal" certbot
It produced this output: requests.exceptions.ConnectTimeout: HTTPSConnectionPool(host='acme-v02.api.letsencrypt.org', port=443): Max retries exceeded with url: /directory (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConnection object at 0x7ff447a3a6b0>, 'Connection to acme-v02.api.letsencrypt.org timed out. (connect timeout=45)'))
The operating system my web server runs on is (include version): Ubuntu 22.04 Jammy
My hosting provider, if applicable, is: Hetzner
Please See Rate Limits - Let's Encrypt and Failed Validation Limit - Let's Encrypt
Currently ama-test.clarity-tec.com is serving a certificate for
Common Name: 	ama-demo.clarity-tec.com
SANs: 			DNS:ama-demo.clarity-tec.com
				Total number of SANs: 1
See here for details https://decoder.link/sslchecker/ama-test.clarity-tec.com/443
Both ama-test.clarity-tec.com and ama-demo.clarity-tec.com resolve to the same IPv4 Address 136.243.94.161
$ nslookup ama-test.clarity-tec.com ns3.stratoserver.net.
Server:         ns3.stratoserver.net.
Address:        185.132.34.159#53
Address: 136.243.94.161
$ nslookup ama-demo.clarity-tec.com ns3.stratoserver.net.
Why?
Hey ! :slight_smile:
Thank you very much for your messages. I worked around the problem by creating the certificates outside my Docker environment and loading them inside the volumes. That's why you see the certificates created.... it works wonderfully. However, my real problem was that the error occurred after I tried to generate the certificates inside docker containers (certbot -> nginx). I can reach both letsencrypt (ping), the DNS seems to work and the firewall was enabled for 443 / 80... I had suspected that I may have run into a rate limiting with my IP. However... I give up and now use the working workaround outside the Docker network :slight_smile: Thanks anyway for dealing with my problem
Outbound? From the docker container?
Does the container have access to DNS?
