Remote check failed for domain xyz.com - WP Encrypt Client
I have been trying to generate a certificate using WP encrypt but end uo getting the error remote check failed for domain can someone point in the right direction ?
hi @atmesh
You are best to contact the author of the plugin and raise this with them.
The error message is specific to the client hence the suggestion
https://wordpress.org/support/plugin/wp-encrypt
Note: last post from them was that they are stopping active development on the plugin
Andrei
