Problem with wp encrypt
it’s a new site and i trid to install let’s encrypt with wp encryption plugin in wordpress.
It couldn’t generate the ssl
Yesterday it worked fine with another wordpress site.
My domain is:www.gaze.com.gr
I ran this command:aplly let’s encrypt through wp encrypt plugin in wordpress
It produced this output:ERROR: CREATE_ORDER:RuntimeException: Error creating new order :: Cannot issue for “gaze.com.gr/wordpress”: Domain name contains an invalid character in /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/lib/LEConnector.php:188
Stack trace:
#0 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/lib/LEConnector.php(228): WPLEClient\WPLEConnector->request(‘POST’, ‘https://acme-v0…’, ‘{“protected”:"e…’)
#1 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/lib/LEOrder.php(173): WPLEClient\WPLEConnector->post(‘https://acme-v0…’, ‘{“protected”:"e…’)
#2 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/lib/LEOrder.php(151): WPLEClient\LEOrder->createOrder(Array, ‘’, ‘’)
#3 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/lib/LEClient.php(172): WPLEClient\LEOrder->__construct(Object(WPLEClient\WPLEConnector), 1, Array, ‘gaze.com.gr/wor…’, Array, ‘rsa-4096’, ‘’, ‘’)
#4 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/classes/le-core.php(132): WPLEClient\WPLEClient->getOrCreateOrder(‘gaze.com.gr/wor…’, Array)
#5 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/classes/le-core.php(88): WPLE_Core->wple_generate_order()
#6 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/classes/le-core.php(72): WPLE_Core->wple_generate_verify_ssl()
#7 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-content/plugins/wp-letsencrypt-ssl/admin/le_admin.php(400): WPLE_Core->__construct(Array)
#8 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-includes/class-wp-hook.php(288): WPLE_Admin->wple_save_email_generate_certs(’’)
#9 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-includes/class-wp-hook.php(312): WP_Hook->apply_filters(NULL, Array)
#10 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-includes/plugin.php(478): WP_Hook->do_action(Array)
#11 /var/www/vhosts/gaze.com.gr/httpdocs/wordpress/wp-admin/admin.php(170): do_action(‘admin_init’)
#12 {main}
My hosting provider, if applicable, is:dnhost.gr
I can login to a root shell on my machine (yes or no, or I don’t know):no
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):plesk onyx
what does this interface look like, what did you type in its settings?
Disclaimer
Security is an important subject regarding SSL/TLS certificates, of course. It is obvious that your private key, stored on your web server, should never be accessible from the web. When the plugin created the keys directory for the first time, it will store a .htaccess file in this directory, denying all visitors. Always make sure yourself your keys aren’t accessible from the web! We are in no way responsible if your private keys go public. If this does happen, the easiest solution is to check folder permissions on your server and make sure public access is forbidden for root folders. Next, create a new certificate.
WHAT THE F...
The only thing standing between a TLS key and its public download is a .htaccess that may even be disabled and only works for apache?
Change client if you can.
it’s e very simple plugin you register and it generates three file for the ssl,you download them and you install them in the plesk panel in the ssl section.
Show me, please. Take screenshots.
it’s just this no other settings
I think it’s a bug in the plugin. click on the ? near the url on top. What does it say?
Hi @serpico
you can create a certificate with www.gaze.com.gr as domain name. Or www.gaze.com.gr + gaze.com.gr.
You can’t create a certificate with a subfolder gaze.com.gr/wordpress.
it says "add a cname with name www pointing to your non-www domain
but this is already done
I’ve checked
the problem is that is adds /wordpress after. you need to understand why.
but my advice is to drop this plugin and use another acme client
the domain was www.gaze.com.gr but it was put there by itself I wasn;t asked for the domain
