Help with WP Encrypt plugin on Wordpress
My domain is: www.bastiaensgroup.nl
And I am trying to get the WP Encrypt plugin to work. I filled in the account settings and clicked on the ‘register account’ button to get an account on Let’s Encrypt.
The help feature tells me that a new button should appear, namely the ‘generate SSL’ button. However, it didn’t. No matter how many times I push the ‘register account’ button. I can’t seem to find a solution anywhere. Can someone help me?
Hi @Receptie
you have an ipv4 and an ipv6 - address ( https://check-your-website.server-daten.de/?q=bastiaensgroup.nl ):
bastiaensgroup.nl A 81.169.145.105 yes 2 0
AAAA 2A01:0238:020A:0202:1105:0000:0000:0000 yes
www.bastiaensgroup.nl C bastiaensgroup.nl yes 1 0
May be a problem because ipv6 isn't configured correct.
And checking /.well-known/acme-challenge there is a critical answer:
• http://www.bastiaensgroup.nl/
81.169.145.105 301 http://bastiaensgroup.nl/ 0.310 D
• http://bastiaensgroup.nl/
81.169.145.105 200 0.973 H
• https://bastiaensgroup.nl/
81.169.145.105 -10 0.040 P
SecureChannelFailure - The request was aborted: Could not create SSL/TLS secure channel.
• https://www.bastiaensgroup.nl/
• http://www.bastiaensgroup.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
81.169.145.105 301 http://bastiaensgroup.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de 0.276 D
• http://bastiaensgroup.nl/.well-known/acme-challenge/check-your-website-dot-server-daten-dot-de
81.169.145.105 -8 0.380 W
ConnectionClosed - The request was aborted: The connection was closed unexpectedly.
The "ConnectionClosed" is bad.
Looks like the WP plugin doesn't understand your configuration.
Okay…Any idea how I can solve it?
Such tools are "closed worlds", so it's nearly impossible.
Check if it works if you remove temporarily your ipv6 address.
It's possible that the blocked /.well-known/acme-challenge is from this tool - > no problem.
Not from this tool -> big problem.
