Problems with renewing certificate
I tried to renew SSL Certificate on my website. It was automatic but now I am getting this error when i try to renew it:
Could not issue an SSL/TLS certificate for pagelife.gr
Details
Could not issue a Let’s Encrypt SSL/TLS certificate for pagelife.gr .
Details
Invalid response from https://acme-v02.api.letsencrypt.org/acme/order/58293345/980502021.
Details:
Type: urn:ietf:params:acme:error:malformed
Status: 404
Detail: No order for ID 980502021
My domain is: http://pagelife.gr/
My hosting provider, if applicable, is: contabo
I can login to a root shell on my machine (yes or no, or I don’t know): no
Plesk
Hi @nassos19
that's a known Plesk bug.
Check
https://support.plesk.com/hc/en-us/articles/360020966774-Unable-to-install-a-Let-s-Encrypt-certificate-Order-s-status-pending-is-not-acceptable-for-finalization
there you find an answer how to fix it.
Hello
I can’t connect to the Plesk server via [SSH] thats my problem
Then check, if there is a Plesk update that fixes that.
If that doesn’t work: Use the Plesk forum to ask.
It’s an internal bug of the Plesk client, so only Plesk can fix it.
ok Thanks for your help
