Hello,
Currently I installed the let’s Encrypt plugin on my cpanel server, but the installation was done when the hostname had a default, but at this point I changed the hostname and is now presenting the error
[SELF-TEST] Has valid license … SUCCESS.
[SELF-TEST] Can read config … SUCCESS.
[SELF-TEST] Can connect to Let’s Encrypt … SUCCESS.
[SELF-TEST] Can talk to WHM API … FAILED: Get https://myhostname.com:2087/json-api/listaccts?api.version=1: x509: certificate signed by unknown authority.
[SELF-TEST] Can talk to RPC plugin … SUCCESS.
Would there be any way to update let’s encrypt settings to recognize the new hostname without having to re-install it?
Thank you
