Cpanel letsencrypt has problem
[root@ams-1022 public_html]# le-cp self-test
[SELF-TEST] Has valid licence … SUCCESS.
[SELF-TEST] Can read config … SUCCESS.
[SELF-TEST] Can connect to Let’s Encrypt … FAILED: Get https://acme-v01.api.letsencrypt.org/directory: dial tcp 23.4.24.253:443: i/o timeout.
[SELF-TEST] Can talk to WHM API … SUCCESS.
[SELF-TEST] Can talk to plugin RPC … SUCCESS.
The self-test failed. You should fix the above issues before continuing, or contact support @ https://cpanel.fleetssl.com/contact
Please first run the following command, which will send us your log files and configuration details:
wget -qq -O - https://cpanel.fleetssl.com/static/generate_support_data.sh|bash
FATA[0030] Self-test failed
Please help
Did you already do the things the message asks of you?
This shows an inability to talk to the certificate authority via HTTPS. Is there a firewall restricting outbound connections?
Can you use curl on this machine to access https://acme-v01.api.letsencrypt.org/directory? How about https://www.google.com/?
