Problem with certificates
My domain is: techcomputerworld.com
I ran this command: certbot-auto renew
root@ubuntu:/home/onzulin# certbot-auto renew
Processing /etc/letsencrypt/renewal/despedidasexclusivas.com.conf
Cert not yet due for renewal
Processing /etc/letsencrypt/renewal/gamesyap.com.conf
Processing /etc/letsencrypt/renewal/juegos.gamesyap.com.conf
Processing /etc/letsencrypt/renewal/mail.gamesyap.com.conf
http-01 challenge for mail.gamesyap.com
http-01 challenge for mail.izquierdaanarkista.info
http-01 challenge for mail.techcomputerworld.com
Attempting to renew cert (mail.gamesyap.com) from /etc/letsencrypt/renewal/mail.gamesyap.com.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6… Skipping.
Processing /etc/letsencrypt/renewal/prueba.gamesyap.com.conf
Processing /etc/letsencrypt/renewal/techcomputerworld.com.conf
Processing /etc/letsencrypt/renewal/test.gamesyap.com.conf
Processing /etc/letsencrypt/renewal/web.techcomputerworld.com.conf
/etc/letsencrypt/live/mail.gamesyap.com/fullchain.pem (failure)
/etc/letsencrypt/live/despedidasexclusivas.com/fullchain.pem expires on 2019-11-19 (skipped)
/etc/letsencrypt/live/gamesyap.com/fullchain.pem expires on 2020-01-07 (skipped)
/etc/letsencrypt/live/juegos.gamesyap.com/fullchain.pem expires on 2019-12-16 (skipped)
/etc/letsencrypt/live/prueba.gamesyap.com/fullchain.pem expires on 2020-01-13 (skipped)
/etc/letsencrypt/live/techcomputerworld.com/fullchain.pem expires on 2019-12-30 (skipped)
/etc/letsencrypt/live/test.gamesyap.com/fullchain.pem expires on 2020-01-14 (skipped)
/etc/letsencrypt/live/web.techcomputerworld.com/fullchain.pem expires on 2019-11-28 (skipped)
My web server is (include version): nginx version: nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu Server 18.04
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.39.0
I'm not sure, but can you renew certificates that expired more than a month ago?
Hi @onzulin
if you use standalone, a new webserver is startet.
But if there is already a running webserver,
so it's impossible to start a new.
So you have two options:
  • stop the running webserver, then start the command (or, better)
  • use the running webserver
There is a nginx, what says
nginx -T
Ok the problem is
root@ubuntu:/etc/nginx/sites-available# nginx -t
nginx: [warn] conflicting server name “mail.gamesyap.com” on 0.0.0.0:80, ignored
It is clear that the problem is in this line
I found the solution in using the command:
certbot-auto renew
But stopping the nginx server and renewing all certificates again
