Problem renewing certificate
My domain is: policy.animaljusticeparty.org
I ran this command: sudo certbot certonly -d policy.animaljusticeparty.org
http-01 challenge for policy.animaljusticeparty.org
Problem binding to port 80: Could not bind to IPv4 or IPv6.
  • Your account credentials have been saved in your Certbot
My web server is (include version): nginx 1.14.0
The operating system my web server runs on is (include version): Ubuntu 18.04.2
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.23.0
Do I need to shutdown nginx before running this command?
Hi @GeoffRussell
looks like you use the standalone authenticator. Then you have to stop your running webserver.
What's the content of your renewal file, located in
/etc/letsencrypt/renewal
  • Stop your running webserver (not so good)
  • use --nginx or --webroot to use your running webserver.
Many thanks … stopping and starting is okay for now … next time I’ll keep the --nginx option in mind. All good.
