Help renewing cert
askbiblescholars.com
I cannot recall the specific command but it failed.
N/A
Ubuntu 20.04.6 LTS (GNU/Linux 5.4.0-152-generic x86_64)
Digital Ocean
Yes
No
certbot 0.40.0
Hi @beehaw,
Could you please try the renewal again and note down what the command was and what it said when it failed? There are many different errors possible, and the specific error message will help us to give you advice about what to do about it.
Processing /etc/letsencrypt/renewal/askbiblescholars.com.conf
http-01 challenge for askbiblescholars.com
Attempting to renew cert (askbiblescholars.com) from /etc/letsencrypt/renewal/askbiblescholars.com.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6.. Skipping.
Processing /etc/letsencrypt/renewal/www.askbiblescholars.com.conf
Attempting to parse the version 2.6.0 renewal configuration file found at /etc/letsencrypt/renewal/www.askbiblescholars.com.conf with version 0.40.0 of Certbot. This might not work.
Cert not yet due for renewal
Could not choose appropriate plugin for updaters: Could not select or initialize the requested installer nginx.
/etc/letsencrypt/live/askbiblescholars.com/fullchain.pem (failure)
/etc/letsencrypt/live/www.askbiblescholars.com/fullchain.pem expires on 2023-09-19 (skipped)
It seems that during your last renewal/issuance certbot was running in standalone mode.
This is not the preferred method when there is a working web service.
That said, you could probably stop your web server and renew the cert and then restart the web server.
Again, that is not an ideal renewal process.
If you can take the time to figure out how to use the web server OR use --webroot through the web server, you may be able to automate this in a manner that won't stop your web site [while renewing].
That's not what is meant by that question. This question meant the actual software used to serve the website, e.g. Apache/nginx/Caddy/whatever.
I stopped the web server and tried again only to get the following (Again):
root@askbiblescholars:/# sudo certbot renew
Which is?
Well, apparently something is still listening on port 80. You could use e.g. sudo netstat -nap | grep 80 to find out which process.
This is weird. So currently you're using Certbot 0.40.0, a very old version, but somewhere in the past you've also used Certbot 2.6.0, one of the most recent versions? Did you install Certbot using multiple methods? E.g. apt and snap perhaps? Is there currently just a single Certbot installed or multiple?
Looks like you have two separate certificates for the same domain. Can you please show the output of sudo certbot certificates ?
Found the following certs:
Certificate Name: askbiblescholars.com
Domains: askbiblescholars.com
Expiry Date: 2023-07-14 17:01:00+00:00 (VALID: 5 days)
Certificate Path: /etc/letsencrypt/live/askbiblescholars.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/askbiblescholars.com/privkey.pem
Certificate Name: www.askbiblescholars.com
Domains: www.askbiblescholars.com
Expiry Date: 2023-09-19 18:58:58+00:00 (VALID: 72 days)
Certificate Path: /etc/letsencrypt/live/www.askbiblescholars.com/fullchain.pem
Private Key Path: /etc/letsencrypt/live/www.askbiblescholars.com/privkey.pem
The goal is to use nginx to get/renew your certs. And, your root name askbiblescholars.com should give the same results as your www subdomain.
Getting to that takes several steps. I see your root domain responding poorly to various routine requests. So, let's fix that first. Can you upload the file from this command? If not, please post entire (long) output here with 3 backticks before and after the output.
sudo nginx -T >upload.txt
If you must paste it like this
output from command
A colleague of mine was able to get this fixed for me. Thanks to everyone ITT for your time and attention!
