Peter7
December 20, 2022, 9:03am
1
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: .com
I ran this command: certbot renew --force-renewal --config-dir cert/
My web server is (include version): tomcat on docker container
The operating system my web server runs on is (include version): Ubuntu 20.04.5 LTS
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): certbot 1.32.2
rg305
December 20, 2022, 9:54am
4
Hi @Peter7 , and welcome to the LE community forum
First, don't use this without knowing what it does:
Peter7:
--force-renewal
It will not force something that is broken to be fixed.
Please show the outputs of:
certbot certificates
cat /root/MappingSite/cert/renewal/www.pyinnyar-subuu.com.conf
Peter7
December 20, 2022, 10:10am
6
version shows as 0.40.0. But i have already updated to 1.32.2
rg305
December 20, 2022, 10:11am
7
Peter7:
authenticator = standalone
Please show:
netstat -pant | grep -i listen | grep 80
rg305
December 20, 2022, 10:14am
9
You can ignore the numbers shown in the renewal config files - that was the version that created the file.
Please also show:
rg305:
And also show:
curl -4 ifconfig.io
rg305
December 20, 2022, 10:17am
12
That is the right IP.
And I don't see anything listening on port 80.
What shows?:
Peter7
December 20, 2022, 10:19am
13
rg305:
Sorry I over looked .
No certificates found.
rg305
December 20, 2022, 10:21am
15
Peter7:
hmm...
Your topic says "Renew" and your command includes "renew".
What happened to the certificate?
rg305
December 20, 2022, 10:22am
16
Peter7:
I already created firewall rule to allow port 80 in both GCP and IP table. Also checked and it is opened.
Not from where I use the Internet.
All I see is "error 400":
curl -Ii4 http://www.pyinnyar-subuu.com/anything
HTTP/1.1 400
Content-Type: text/plain;charset=UTF-8
Connection: close
Is the NAT correct?
[same as port 443]
rg305
December 20, 2022, 10:23am
18
Did you delete the certificate?
rg305
December 20, 2022, 10:40am
21
Wait a minute!
That shows the NAT going to port 8080 [wWhich is help by Docker].
Are you running certbot in the right container?
rg305
December 20, 2022, 10:54am
24
How was it set when you last renewed?
Yeah, I got 400 for every HTTP request.
rg305
December 20, 2022, 10:56am
26
Peter7:
2 3 164 REDIRECT tcp -- * * 0.0.0.0/0 0.0.0.0/0 tcp dpt:80 redir ports 443
You should never port forward 80 to 443.
Peter7:
It worked as per normal.
Nothing "normal" there.
Revisit your notes.
Peter7
27
noted i will revert back to previous rules
