Certificate Renewal Issue
aiting for verification...
Challenge failed for domain xyz.com
http-01 challenge for xyz.com
    Domain: xyz.com
    Detail: XX.XX.XX.XX: Invalid response from
    https://xyz.com/.well-known/acme-challenge/NIRihEnLkoTacUsoOOvxqE5XQFV58X3ThQyltlvOnQ4:
    404
    Apache/2.4.58
    Cent os 7
I can login to a root shell on my machine (yes or no, or I don't know):Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot):certbot 1.11.0
Well, you should check your IP address because that domain is being handled by an nginx server. Have you changed your IP recently?
And, what relation does gen.xyz have to your xyz.com domain?
curl -i http://xyz.com
Server: nginx/1.15.12
X-Powered-By: PHP/5.5.9-1ubuntu4.29
If xyz.com is not your domain, please provide your real domain and do not use other people's domains as examples.
No IP is same and it's Apache Server.
Is xyz.com your real domain?
Lol, that's the registry for .xyz
