Nginx problem binding to port 80
My domain is: www.registrationcenter.net
I ran this command: sudo certbot renew --dry-run
Processing /etc/letsencrypt/renewal/www.registrationcenter.net.conf
http-01 challenge for www.registrationcenter.net
Attempting to renew cert (www.registrationcenter.net) from /etc/letsencrypt/renewal/www.registrationcenter.net.conf produced an unexpected error: Problem binding to port 80: Could not bind to IPv4 or IPv6… Skipping.
/etc/letsencrypt/live/www.registrationcenter.net/fullchain.pem (failure)
My web server is (include version): nginx/1.4.6 (Ubuntu)
Ubuntu 14.04.5 LTS (GNU/Linux 3.13.0-147-generic x86_64)
My hosting provider, if applicable, is: myself
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.28.0
Additional info: nmap shows an open port 80
nmap www.registrationcenter.net
Starting Nmap 6.47 ( http://nmap.org ) at 2019-01-29 16:59 CST
Nmap scan report for www.registrationcenter.net (10.28.1.92)
Host is up (0.0033s latency).
Not shown: 996 closed ports
PORT STATE SERVICE
22/tcp open ssh
80/tcp open http
443/tcp open https
8443/tcp open https-alt
Nmap done: 1 IP address (1 host up) scanned in 0.28 seconds
The problem is you are now using Nginx (as your web server) and the previously selected plugin is standalone, which means you’ll need to stop Nginx and run the renew.
However, I do think the best way to resolve this is not stop Nginx before renew, is to switch authenticator plugin to Nginx (hence reduce downtime and other issues)
If you are willing to switch to Nginx plugin, please execute the following command:
sudo certbot renew --cert-name www.registrationcenter.net -a nginx --force-renewal
(Please use force renewal, in case certbot does not change / save the new auth to this config file)
Thank you
Thank you! That appears to have worked.
