Problem to renew certificate
sudo certbot renew
    Domain: midgard.crabdance.com
    Detail: 79.203.102.46: Invalid response from
    Nextcloud "\n<html class="ng-csp" data-placeholder-focus="false"
    lang="en" data-locale="en" >\n\t<head\n
    data-requesttoken="brGT"
Server version: Apache/2.4.41 (Ubuntu)
Ubuntu 20.04.4 LTS
no
certbot 0.40.0
Output 'sudo apachectl-S':
AH00558: apache2: Could not reliably determine the server's fully qualified domain name, using 127.0.1.1. Set the 'ServerName' directive globally to suppress this message
VirtualHost configuration:
*:443 is a NameVirtualHost
default server 127.0.1.1 (/etc/apache2/sites-enabled/default-ssl.conf:2)
port 443 namevhost 127.0.1.1 (/etc/apache2/sites-enabled/default-ssl.conf:2)
port 443 namevhost midgard.crabdance.com (/etc/apache2/sites-enabled/nextcloud-le-ssl.conf:2)
*:80 midgard.crabdance.com (/etc/apache2/sites-enabled/nextcloud.conf:1)
ServerRoot: "/etc/apache2"
Define: DUMP_VHOSTS
Define: DUMP_RUN_CFG
User: name="www-data" id=33
Group: name="www-data" id=33
Hi @mh23, and welcome to the LE community forum :slight_smile:
It seems that something changed in March:
As the regular renewal cycle was broken.
And now the renewal is failing...
We should have a look at the file:
[which is where we should be handling the challenge requests]
In March I moved my nextcloud from a pi (OS was nextcloudpi) to a pc (OS is now ubuntu with a new nextcloud installation) with the same domain.
Here is the nextcloud.conf:
<VirtualHost *:80>
   DocumentRoot /var/www/nextcloud/
   ServerName midgard.crabdance.com
   #ServerAlias www.yourdomain.com
   #Redirect permanent / https://midgard.crabdance.com/
<Directory /var/www/nextcloud/>
   Options +FollowSymlinks
   AllowOverride All
   Require all granted
<IfModule mod_dav.c>
   Dav off
</IfModule>
   SetEnv HOME /var/www/nextcloud
   SetEnv HTTP_HOME /var/www/nextcloud
</Directory>
RewriteEngine on
RewriteCond %{SERVER_NAME} =midgard.crabdance.com
</VirtualHost>
Your Apache VirtualHost for port 80 is redirecting all requests to HTTPS and your HTTPS VirtualHost redirects the acme-challenge request to your login page. You need the server to respond with the acme challenge token value instead. There are many ways to correct this. One is to update your rewrite rules by adding this line immediately after RewriteEngine on
RewriteRule ^/\.well-known/.+ - [END]
This will prevent the /.well-known/acme-challenge/TokenValue request from being redirected to your https server.
As long as your DocumentRoot for the http VirtualHost is correct the cert renewal should be fine.
If that doesn't do the trick, try this line above the RewriteRule:
RewriteCond %{REQUEST_URI} !^/.well-known/acme-challenge [NC]
I tested both suggestions one after the other but it didn´t work.
I checked the DocumentRoot. In the files 000-default.conf and default-ssl.conf it was '/var/www/html'. I changed the path in '/var/www/nextcloud' and tried again both suggestions.
I get again the same error message
data-requesttoken="B3iQ"
Any further ideas?
More of the same.
Try each of those (again); But this time create a test text file in the expected challenge location.
And see if it can be accessed directly from the Internet.
mkdir -p /var/www/nextcloud/.well-known/acme-challenge
echo "test" > /var/www/nextcloud/.well-known/acme-challenge/Test_File-1234
http://midgard.crabdance.com/.well-known/acme-challenge/Test_File-1234
I can access the file.
hmm...
Then can you get a cert now?
no, same error again
Try:
sudo certbot certonly --webroot -w /var/www/nextcloud -d midgard.crabdance.com --dry-run
It works :smiley:
http-01 challenge for midgard.crabdance.com
Using the webroot path /var/www/nextcloud for all unmatched domains.
  • The dry run was successful.
But why does it only work with those additionally parameters?
Ok, now get the cert:
It seems that certbot is unable to handle the syntax of the configuration file.
I suspect the unblanced:
has thrown it off its' game.
So, we overcame that by explicitly telling certbot where to place the challenge file.
