Help after renew my cert
My domain is:https://magiciptv.co.uk/billing/admin/login.php
I ran this command:sudo certbot --apache
My web server is (include version):apache 2
The operating system my web server runs on is (include version):ubuntu 14,4 64 bit
My hosting provider, if applicable, is:contabo
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
It seems like your webserver is misconfigured and is not using your existing Let’s Encrypt certificates.
What’s this show:
apachectl -t -D DUMP_VHOSTS
Since you’re currently affected by rate limits you won’t be able to renew right now, but you shouldn’t need to.
OK.
So we know that Certbot has not actually installed any certificates into Apache yet.
We want to do that as your final goal, but we need to figure out what certificates are available to install. What does this show:
sudo certbot certificates
ok i think i sorted the cert for the first domain can i add cert to each domain in my server ?
Hi @gemihema
yes, that should work. Find your correct vHost (port 443), there should be something like
        SSLEngine on
        SSLCertificateKeyFile /etc/ssl.key/example.com.key
        SSLCertificateFile /etc/ssl.crt/example.com.crt
Instead of
use (sample).
        SSLCertificateFile /etc/letsencrypt/live/www.magiciptv.co.uk/fullchain.pem
        SSLCertificateKeyFile /etc/letsencrypt/live/www.magiciptv.co.uk/privkey.pem
DocumentRoot "/var/www/html/magiciptv/" ServerName www.magiciptv.co.uk ServerAlias magiciptv.co.uk Include /etc/letsencrypt/options-ssl-apache.conf ServerAlias expressiptv.com SSLCertificateFile /etc/letsencrypt/live/magiciptv.co.uk/cert.pem SSLCertificateKeyFile /etc/letsencrypt/live/magiciptv.co.uk/privkey.pem SSLCertificateChainFile /etc/letsencrypt/live/magiciptv.co.uk/chain.pem DocumentRoot "/var/www/html/express/" ServerName www.expressiptv.com
what should i change there to add cert to expressiptv.com as well
Certbot should (ideally) be installing these for you - you shouldn’t need to make any configuration changes.
What does Certbot say when you run the following:
sudo certbot --apache --reinstall -d magiciptv.co.uk
root@magiciptv:/etc/apache2/sites-enabled# sudo certbot --apache --reinstall -d magiciptv.co.uk
Cert not yet due for renewal
Deploying Certificate to VirtualHost /etc/apache2/sites-enabled/000-default-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel):
thing is i think i got magiciptv to wok ok now but all express iptv redirect to magic iptv so i think it s mising in configuration
Huh, looks like it’s already been setup - https://magiciptv.co.uk/
You can try the same command for your other domains.
