My domain is: lab.addmoreroutes.com
I ran this command: certbot-auto -d lab.addmoreroutes.com
Upgrading certbot-auto 0.36.0 to 0.39.0…
Replacing certbot-auto…
Creating virtual environment…
Installing Python packages…
Installation succeeded.
http-01 challenge for lab.addmoreroutes.com
Waiting for verification…
Created an SSL vhost at /etc/apache2/sites-available/unetlab-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/unetlab-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/unetlab-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 2
Added an HTTP->HTTPS rewrite in addition to other RewriteRules; you may wish to check for overall consistency.
Redirecting vhost in /etc/apache2/sites-enabled/unetlab.conf to ssl vhost in /etc/apache2/sites-available/unetlab-le-ssl.conf
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://lab.addmoreroutes.com
https://www.ssllabs.com/ssltest/analyze.html?d=lab.addmoreroutes.com
Congratulations! Your certificate and chain have been saved at:
/etc/letsencrypt/live/lab.addmoreroutes.com/fullchain.pem
/etc/letsencrypt/live/lab.addmoreroutes.com/privkey.pem
Your cert will expire on 2020-02-02. To obtain a new or tweaked
version of this certificate in the future, simply run certbot-auto
again with the “certonly” option. To non-interactively renew all
of your certificates, run “certbot-auto renew” -
Some rewrite rules copied from
/etc/apache2/sites-enabled/unetlab.conf were disabled in the vhost
for your HTTPS site located at
/etc/apache2/sites-available/unetlab-le-ssl.conf because they have
the potential to create redirection loops. -
Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
N/A or Guacamole/EVE-NG
Ubuntu 16.04.6 LTS
N/A
I SSH
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): 0.39.0
I was trying to issue a renewal and mistakenly hit option #2 and now not able to get to the server locally/remotely using the url address. I can still access the server via root on ip address. How can I restore the configuration to an earlier date/time etc ??
