LetsEncrypt / Certificate Renewal Issue (Ongoing Issue)
lab.addmoreroutes.com
certbot-auto -d lab.addmoreroutes.com
root@eve-ng:~# certbot-auto -d lab.addmoreroutes.com
http-01 challenge for lab.addmoreroutes.com
Waiting for verification…
Created an SSL vhost at /etc/apache2/sites-available/unetlab-le-ssl.conf
Deploying Certificate to VirtualHost /etc/apache2/sites-available/unetlab-le-ssl.conf
Enabling available site: /etc/apache2/sites-available/unetlab-le-ssl.conf
new sites, or if you’re confident your site works on HTTPS. You can undo this
change by editing your web server’s configuration.
Select the appropriate number [1-2] then [enter] (press ‘c’ to cancel): 1
Future versions of Certbot will automatically configure the webserver so that all requests redirect to secure HTTPS access. You can control this behavior and disable this warning with the --redirect and --no-redirect flags.
Your existing certificate has been successfully renewed, and the new certificate
has been installed.
The new certificate covers the following domains: https://lab.addmoreroutes.com
https://www.ssllabs.com/ssltest/analyze.html?d=lab.addmoreroutes.com
    /etc/letsencrypt/live/lab.addmoreroutes.com/fullchain.pem
    /etc/letsencrypt/live/lab.addmoreroutes.com/privkey.pem
    Your cert will expire on 2020-07-10. To obtain a new or tweaked
    version of this certificate in the future, simply run certbot-auto
    again with the “certonly” option. To non-interactively renew all
    of your certificates, run “certbot-auto renew”
  • Some rewrite rules copied from
    /etc/apache2/sites-enabled/unetlab.conf were disabled in the vhost
    for your HTTPS site located at
    /etc/apache2/sites-available/unetlab-le-ssl.conf because they have
    the potential to create redirection loops.
    Donating to ISRG / Let’s Encrypt: https://letsencrypt.org/donate
Ubuntu 16.04 LTS
N/A
certbot 1.3.0
I am running a homelab (EVE-NG) and from time to time I manually update the Letsencrypt certificate and run into problems. These problems are of my own doing and I have a history of fumbling through this process. I tried before on doing a script to auto renew but was unsuccessful. Long story short…
I successfully renew my certificate but I am unable to access the server remotely and locally. Access forbidden when trying to access locally. Please help
root@eve-ng:~# tail -n 20 /opt/unetlab/data/Logs/ssl-error.log
[Fri Apr 10 18:15:10.377635 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 06:25:01.594680 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 12:35:33.538065 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 12:35:47.183454 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 12:56:50.689710 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 12:56:55.107322 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 12:56:57.366963 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 12:58:36.665119 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 13:01:49.553165 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 13:11:58.883723 2020] [ssl:warn] [pid 14090] AH01909: eve-ng.example.com:443:0 server certificate does NOT include an ID which matches the server name
[Sat Apr 11 13:12:26.674281 2020] [authz_core:error] [pid 9625] [client x.x.x.x:63583] AH01630: client denied by server configuration: /opt/unetlab/html/, referer: https://x.x.x.x
[Sat Apr 11 13:12:26.709888 2020] [authz_core:error] [pid 9625] [client x.x.x.x:63583] AH01630: client denied by server configuration: /opt/unetlab/html/favicon.ico, referer: https://x.x.x.x
[Sat Apr 11 13:12:49.958741 2020] [authz_core:error] [pid 9626] [client x.x.x.x:63599] AH01630: client denied by server configuration: /opt/unetlab/html/, referer: https://x.x.x.x
root@eve-ng:/etc/apache2/sites-enabled# sudo nano eveng-ssl.conf
GNU nano 2.5.3 File: eveng-ssl.conf
ServerAdmin webmaster@localhost DocumentRoot /opt/unetlab/html/ ErrorLog /opt/unetlab/data/Logs/ssl-error.log CustomLog /opt/unetlab/data/Logs/ssl-access.log combined Alias /Exports /opt/unetlab/data/Exports Alias /Logs /opt/unetlab/data/Logs SSLEngine on SSLProxyEngine on SSLCertificateFile /etc/letsencrypt/live/lab.addmoreroutes.com/fullchain.pem SSLCertificateKeyFile /etc/letsencrypt/live/lab.addmoreroutes.com/privkey.pem SSLProtocol all -SSLv3 -TLSv1 -TLSv1.1 # Many ciphers defined here require a modern version (1.0.1+) of OpenSSL. Some # require OpenSSL 1.1.0, which as of this writing was in pre-release. SSLCipherSuite ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RS$ SSLHonorCipherOrder on SSLCompression off SSLSessionTickets off SSLOptions +StdEnvVars SSLOptions +StdEnvVars Order allow,deny Allow from all ProxyPass http://127.0.0.1:8080/guacamole/ flushpackets=on ProxyPassReverse http://127.0.0.1:8080/guacamole/
    <Location /html5/websocket-tunnel>
            Order allow,deny
            Allow from all
            ProxyPass ws://127.0.0.1:8080/guacamole/websocket-tunnel
            ProxyPassReverse ws://127.0.0.1:8080/guacamole/websocket-tunnel
    </Location>
     ProxyPass /janus-ws ws://127.0.0.1:8188/
     ProxyPassReverse /janus-ws ws://127.0.0.1:8188/
     ProxyPass /chat-ws ws://127.0.0.1:9090/
     ProxyPassReverse /chat-ws ws://127.0.0.1:9090/
</VirtualHost>
root@eve-ng:~# certbot-auto --version
certbot 1.3.0
root@eve-ng:~# apachectl -t
Syntax OK
root@eve-ng:~# apachectl -t -D DUMP_VHOSTS
VirtualHost configuration:
*:443 eve-ng.example.com (/etc/apache2/sites-enabled/eveng-ssl.conf:2)
Your problem is within the Apache configuration (or lack thereof).
The domain:
is not covered; as shown by the config:
And the error logs show that the "default" server name is not covered by the cert:
You've already done all the work to get a valid cert and all the troubleshooting...
Now, you just need to understand all of it and take the proper action.
I didnt do too much troubleshooting besides posting some logs and ouput. Can you guide me in the right direction as far as the Apache configuration you mentioned ?
Not really.
This is an LE community forum - not an Apache community forum.
[a simple web search should provide you all the information needed and even examples]
I have corrected some things but still not having the best of luck. I have tried doing a number of Google searches on Apache configuration but just not seeing it at the moment. Keep in mind that I am a novice at best when it comes to Linux.
*:443 lab.addmoreroutes.com (/etc/apache2/sites-enabled/eveng-ssl.conf:2)
[Sat Apr 11 13:13:44.071087 2020] [authz_core:error] [pid 9628] [client x.x.x.x:63606] AH01630: client denied by server configuration: /opt/unetlab/html/, referer: https://x.x.x.x/
[Sat Apr 11 13:13:44.089161 2020] [authz_core:error] [pid 9628] [client x.x.x.x:63606] AH01630: client denied by server configuration: /opt/unetlab/html/favicon.ico, referer: https://x.x.x.x/
What is the config?:
Blockquote
ServerName lab.addmoreroutes.com
ServerAlias www.lab.addmoreroutes.com
SSLEngine on
SSLProxyEngine on
SSLCompression off
<FilesMatch ".(cgi|shtml|phtml|php)$">
<Directory /usr/lib/cgi-bin>
<Location /html5/>
Order allow,deny
Allow from all
            Order allow,deny
            Allow from all
    </Location>
</VirtualHost>
Blockquote
Where is the "default" ("location /") handler?
Not sure of what you mean ? please elaborate…Linux/Apache rookie here
Will handles requests like:
http[s]://[www.]lab.addmoreroutes.com/html5/[*]
http[s]://[www.]lab.addmoreroutes.com/html5/websocket-tunnel[/*]
What handles any requests NOT like either of those?
Like just:
http[s]://[www.]lab.addmoreroutes.com[/*]
I dont believe its there or am I missing something
Yes, exactly, you are missing something.
What do you want requests to https://lab.addmoreroutes.com/ to do?
Maybe you want to just redirect them to https://addmoreroutes.com/
Maybe you want to show them a “splash” page that says: “This is for official LAB workers only - stay out!”
Maybe you want to display kittens trying to catch balls of yarn…
You decide and control what happens.
You need to decide.
Then you need to make it do whatever you decided.
That “happens” within a “location” section [the one that is missing].
Whats an example look like ?
<Location "/">
   #redirect all "lost and unfound" requests to main site
   return 301 https://addmoreroutes.com/
</Location>
See: http://httpd.apache.org/docs/current/mod/core.html#location
I was able to look at a backup file on the Server dating back to August of last year when this was working and the location block seems similar with no extra config. The http/https requests redirect to a EVE-NG login page
[we’re getting off track]
What does certbot certificates say?
what command are you looking for me to run ?
Probably
certbot-auto certificates
in your environment.
