My domain is: http://www.howtoquitdayjob.com
I ran this command: Generate All With Lets Encrypt
It produced this output:» Installing SSL Certificate failed!
» Check LetsEncrypt log at: SiteWorx > Administration > Logs
Under Administration logs I get the following error message: Domain: howtoquitdayjob.com
Type: connection
Detail: Fetching
http://www.howtoquitdayjob.com/.well-known/acme-challenge/C67U73rGbdcEyaYUjO8saQ9iMdHZCIMq8EKj2SEkxCI:
Connection reset by peer
Domain: www.howtoquitdayjob.com
Type: connection
Detail: Fetching
http://www.howtoquitdayjob.com/.well-known/acme-challenge/Dlw-1foWv1IVBgGY_jmLcAlW-L-OjWAPd7RpV7BPUBU:
My hosting provider, if applicable, is: Siteworx
