Not Marked Unread
Sometimes topics with new messages/posts are not marked as unread.
Can only tell they have new messages/posts because their title/subject font is faintly darker.
yeah… i also get that too
The difference between gray and black is quite obvious here, but it may be different with different displays or visual abilities, maybe a different color can help you?
.title:not(.visited) { color: #08e !important; }
For me, something stronger is more distracting TBH.
If you’re talking about the circle with the number of unread posts, that’s because you’re not tracking that specific topic. There’s a setting, it defaults to set topics to tracked state once you read it for at least 4 minutes. You can change it to “immediately”, so you’ll always get that circle once you visited a topic.
Ah’ha, I see. Thanks. I’ll have to consider changing the reading time to track setting.
Yes the difference between the gray and black title is a little faint.
Perhaps adding bold to the title/subject would help.
You have to be judicious with that - really, bold should only be used if you've read most of the topics, which is much more common on a low-traffic forum than a high-traffic one.
