Not able to renew ssl certificate
My domain is:vataly.com
I ran this command:sudo lego --tls --email=“Address” --domains=“vataly.com” --path="/etc/lego" renew
It produced this output:email address not registered use run to register an address.
The operating system my web server runs on is (include version):linux - ubuntu
My hosting provider, if applicable, is:AWS
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):no
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):not using certbot used lego
Hi @dhaval
I don't use lego. But that sounds that you have first to register that email, so Lego knows which account you want to use.
How do I know which account was used while creating certificate , because as per my knowledge goes I am using correct email address !
Check the Lego-documentation. Or create a new account with your current mail address.
