SSL Certificate renewal issue
My domain is: www.1rs.io
sudo /opt/bitnami/letsencrypt/lego --tls --email=“ericsupport@1rs.io” --domains=“1rs.io” --domains=“www.1rs.io” --domains=“*.1rs.io” --path="/opt/bitnami/letsencrypt" renew --days 90
2020/06/01 10:46:15 No key found for account “ericsupport@1rs.io”. Generating a P384 key.
2020/06/01 10:46:15 Saved key to /opt/bitnami/letsencrypt/accounts/acme-v02.api.letsencrypt.org/“ericsupport@1rs.io”/keys/“ericsupport@1rs.io”.key
2020/06/01 10:46:16 Account “ericsupport@1rs.io” is not registered. Use ‘run’ to register a new accountWhich server blocks would you like to modify?
nginx version: nginx/1.16.1
NO, I didn’t configure the SSL via Control Panel, but did it via by logging into EC2 instance.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): Am not using certbot I believe, when I type certbot --version or certbot-auto --version, it says command not found.
Note: I'm not familiair with the lego client, nor with Bitname. But this error message:
Gives a hint. Did you try using the run command?
Also, do you really need to use all those options like --email and --domains again for the renew command of lego?
Email is mandatory for renewal. I had earlier registered using the same email id and getting reminders from Let’s Encrypt for the certificate renewals.
I was able to successfully renew the certificate.
I had to rerun lego for registration, post which new certificates were obtained.
Also it has to be noted that I had to use the http challenge as TLS or DNS was not working for me.
