Not able to renew SSL certificates
siddharthvankudre.online
sudo /opt/bitnami/letsencrypt/lego --tls --email="EMAIL-ADDRESS" --domains="DOMAIN" --path="/opt/bitnami/letsencrypt" renew --days 90
could not create client : get directory at 'https://acme-v02.api.letsencrypt.org/directory ': Get https://acme-v02.api.letsencrypt.org/directory : dial tcp 172.65.32.248:443: i/o timeout
Hi @Sidd02, and welcome to the LE community forum :slight_smile:
Your system is having trouble reaching:
It could be a firewall rule blocking outbound requests.
It could be a routing misconfiguration.
[both of which would be handled by you, or your ISP/HSP]
Hey @rg305 Thank you for the solution, actually the outbound for port 443 and 80 was being blocked removed it successfully.
Regards!!
