SSL renew issue
My domain is: https://apis.ideationtec.com/
I ran this command: sudo certbot renew
Processing /etc/letsencrypt/renewal/apis.ideationtec.com.conf
Failed to renew certificate apis.ideationtec.com with error: ('Connection aborted.', error(101, 'Network is unreachable'))
** /etc/letsencrypt/live/apis.ideationtec.com/fullchain.pem (failure)**
My web server is (include version): apache2
The operating system my web server runs on is (include version): centos 7
Show me the output of
curl -vvv https://acme-v02.api.letsencrypt.org/directory
[root@apis ~]# curl -v https://acme-v02.api.letsencrypt.org/directory
Are you sure your server is online?
It smells like network misconfiguration or overzealous firewall.
Try curl -v4 https://acme-v02.api.letsencrypt.org/directory, might be an IPv6 issue.
It looks like it's both
yes server is online ping is working traceroute is attached.
82.178.159.61 isn't Let's Encrypt. It belongs to some ISP from Oman.
Try:
traceroute --icmp acme-v02.api.letsencrypt.org
traceroute --tcp acme-v02.api.letsencrypt.org (this might need sudo)
True true. I see it now. Although the errors are different.
