Not able to get Certificate on Synology DS916+
I did need to reinstall my DS916+ as due to hard disk problems, but i forgot to
take a backup of the certificates now i am not able to create new ones…
My domain is: lenior.biz(and others)
I ran this command: I tried to install certificate for my synology using configuration menu.
It produced this output: message “Could not connect to Lets Encrypt, please check if the domain is valid”
DSM 6.1.1-15101-Update 2
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):yes
Any advice or fix would be help full
MikeY
Hi @mlenior
Have a search for synology on this forum
As synology writes their own client you are best to talk about issues on the synology forums
“Could not connect to Lets Encrypt, please check if the domain is valid” is a message from the Synology client
Andrei
