I am trying to host my (first) website with nginx via ubuntu on a vm instance with google cloud, on a domain registered with google domains. I mostly followed the steps outlined through this guide.
I can access the website via the IP address but not via the url, which is probably why I’m getting the following error but I cannot work out how to fix it .
My domain is: ownintothefoam.com
I ran this command: sudo certbot --nginx certonly
Gives output:
1: ownintothefoam.com
2: www.ownintothefoam.com
http-01 challenge for ownintothefoam.com
Failed authorization procedure. ownintothefoam.com (http-01): urn:ietf:params:acme:error:dns :: No valid IP addresses found for ownintothefoam.com
Domain: ownintothefoam.com
Type: None
Detail: No valid IP addresses found for ownintothefoam.com
My web server: Nginx 1.10.3
The operating system my web server runs on: 16.04 LTS
My hosting provider: Google
I’m using a control panel to manage my site: no
The version of my client: 0.31.0
My custom resources on domains.google:
| ownintothefoam.com | A | 1h | 35.197.176.213 |
| www.ownintothefoam.com | CNAME | 1h | ownintothefoam.com. |
My name servers are set to use google name servers.
My sites-available/sites-enabled file:
listen 80 default_server;
root /var/www/ownintothefoam.com;
index index.html;
server_name ownintothefoam.com www.ownintothefoam.com;
try_files $uri $uri/ =404;
Any help is much appreciated.
