Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: lawnveteran.com
I ran this command: sudo certbot --nginx -d lawnveteran.com -d www.lawnveteran.com
http-01 challenge for lawnveteran.com
Waiting for verification…
Failed authorization procedure. lawnveteran.com (http-01): urn:ietf:params:acme:error:dns :: No valid IP addresses found for lawnveteran.com
My web server is (include version): Digital Ocean
My hosting provider, if applicable, is: Digital Ocean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): No.
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
rg305
April 2, 2020, 4:50am
2
There is no DNS IP for the base name:
[empty]
Addresses: 2604:a880:800:c1::18d:4001
142.93.181.82
But why does it say that if I can access my website correctly.
9peppe
April 2, 2020, 12:44pm
4
Because browsers are too smart and add www by themselves. Copy the addresses to the base domain too.
You currently have:
www IN A 142.93.181.82
www IN AAAA 2604:a880:800:c1::18d:4001
You should have:
@ IN A 142.93.181.82
@ IN AAAA 2604:a880:800:c1::18d:4001
Does it takes time to reflect the change? I added @ in A and @ in AAA in my Digital Ocean.
9peppe
April 2, 2020, 1:45pm
6
Few seconds to few minutes
Thanks you the best!!! How do you know all this? I can know all programming languages but if I don’t know how to configure a server it makes no sense.
9peppe
April 2, 2020, 1:51pm
8
Thanks for sharing. Hopefully someone else in here will find this very useful.
But now i try to do a re run for renewal to see if it will renew and i get the same error as before.
how you get this information?
now it worked. so interesting. Where can i get
9peppe
April 2, 2020, 2:28pm
15
where can you get your dns records?
you can type whatever you want in there, as long as it points to actual servers. @ just means “the top domain in this zone.”
Yeah but where can I get the information itself for my DNS
Like this:
I mean you got it from somewhere.
9peppe
April 2, 2020, 2:33pm
19
I copied it from your own posts. You can also get it from the dns servers using dig or nslookup.
9peppe
April 2, 2020, 2:34pm
21
You did, just not in that format
Ahh I see dig or dnslookup! Man you are too good!
