No valid IP addresses found for googlevactions.tk. Using certbot with Nginx on Ubuntu 18.04
My domain is: googlevactions.tk
sudo certbot --nginx -d googlevactions.tk -d www.googlevactions.tk
http-01 challenge for googlevactions.tk
Failed authorization procedure. googlevactions.tk (http-01): urn:ietf:params:acme:error:dns :: No valid IP addresses found for googlevactions.tk
    Domain: googlevactions.tk
    Type: None
    Detail: No valid IP addresses found for googlevactions.tk
nginx version: nginx/1.14.0 (Ubuntu)
ubuntu 18.04
freenom
certbot 0.31.0
Hi @sree7k7
there are checks of your domain - https://check-your-website.server-daten.de/?q=googlevactions.tk
There you see the problem:
googlevactions.tk A yes 1 0
AAAA yes
www.googlevactions.tk A 34.254.252.80 Dublin/Leinster/Ireland (IE) - Amazon Technologies Inc. Hostname: ec2-34-254-252-80.eu-west-1.compute.amazonaws.com yes 1 0
AAAA yes
Your non-www version doesn't have an ip address (A-record).
So you can't create a certificate with that domain name.
Add the same A-record, that your www version has.
Then recheck your domain to see, if the A-record is visible.
Some global DNS systems don’t (or won’t) resolve the IP (yet).
Perhaps they are very “new” and need time to synchronize.
Otherwise, there may be a DNSSEC issue?
8.8.8.8 shows:
** 8.8.8.8 can’t find googlevacations.tk: Non-existent domain
1.1.1.1 shows:
*** 1.1.1.1 can’t find googlevacations.tk: Server failed
4.2.2.2 shows:
Addresses: 23.217.138.108
23.202.231.167
208.67.222.220 shows:
*** 208.67.222.220 can’t find googlevacations.tk: Non-existent domain
and DNS SPY shows:
[https://dnsspy.io/scan/googlevacations.tk]
still I am getting error:
**root@ip-172-31-16-13:/home/ubuntu# sudo certbot --nginx -d googlevactions.tk -d www.googlevactions.tk
An unexpected error occurred:
There were too many requests of a given type :: Error creating new order :: too many failed authorizations recently: see https://letsencrypt.org/docs/rate-limits/
Please see the logfiles in /var/log/letsencrypt for more details.**
thanks for your reply.
I have added nameservers. I am using aws route 53 to host the site.
problem solved by adding ipv4 address in create record set.
Thanks a lot!
There is a new check of your domain.
Good: Now you have a valid certificate.
Not so good:
That's
fe80::457:d7ff:fef6:bea4
a private ipv6 address, not a public (like 192.168.*).
Your
doesn't have an ipv6 address.
I got the certificate from certbot but I am unable to see the index.html page.
when I type my URL (https://www.myportlink.cf) in browser, it doesn’t show the o/p.
Please suggest me what I am missing.
Many thanks!
Your IP is NOT responding to port 443 (it does to port 80).
Make sure the firewalls are open for both ports (and they forward to the correct IP).
There is a check of your domain - https://check-your-website.server-daten.de/?q=myportlink.cf
The new certificate is created.
http redirects to https. But https has a timeout.
Works https internal?
curl https://myportlink.cf/
curl https://www.myportlink.cf/
from that server.
If yes, it's a firewall problem.
If the content is wrong, share the vHost config.
It’s not working internal:
These outputs aren’t relevant. Your vHost configuration is required.
nginx -T
    root@ip-172-31-1-80:/home/ubuntu# nginx -T
user www-data;
worker_processes auto;
pid /run/nginx.pid;
events {
        worker_connections 768;
        # multi_accept on;
http {
        # Basic Settings
        sendfile on;
        tcp_nopush on;
        tcp_nodelay on;
        keepalive_timeout 65;
        types_hash_max_size 2048;
        # server_tokens off;
         server_names_hash_bucket_size 64;
        # SSL Settings
        ssl_protocols TLSv1 TLSv1.1 TLSv1.2; # Dropping SSLv3, ref: POODLE
        ssl_prefer_server_ciphers on;
        # Logging Settings
        # Gzip Settings
        gzip on;
        # gzip_vary on;
        # gzip_proxied any;
        # gzip_comp_level 6;
        # gzip_buffers 16 8k;
        # gzip_http_version 1.1;
        # Virtual Host Configs
#mail {
#       # See sample authentication script at:
#       # http://wiki.nginx.org/ImapAuthenticateWithApachePhpScript
#       # auth_http localhost/auth.php;
#       # pop3_capabilities "TOP" "USER";
#       # imap_capabilities "IMAP4rev1" "UIDPLUS";
#       server {
#               listen     localhost:110;
#               protocol   pop3;
#               proxy      on;
#       server {
#               listen     localhost:143;
#               protocol   imap;
#               proxy      on;
# configuration file /etc/nginx/modules-enabled/50-mod-http-geoip.conf:
load_module modules/ngx_http_geoip_module.so;
types {
    text/html                             html htm shtml;
    text/css                              css;
    text/xml                              xml;
    image/gif                             gif;
    image/jpeg                            jpeg jpg;
    application/javascript                js;
    application/atom+xml                  atom;
    application/rss+xml                   rss;
    text/mathml                           mml;
    text/plain                            txt;
    text/vnd.sun.j2me.app-descriptor      jad;
    text/vnd.wap.wml                      wml;
    text/x-component                      htc;
    image/png                             png;
    image/tiff                            tif tiff;
    image/vnd.wap.wbmp                    wbmp;
    image/x-icon                          ico;
    image/x-jng                           jng;
    image/x-ms-bmp                        bmp;
    image/svg+xml                         svg svgz;
    image/webp                            webp;
    application/font-woff                 woff;
    application/java-archive              jar war ear;
    application/json                      json;
    application/mac-binhex40              hqx;
    application/msword                    doc;
    application/pdf                       pdf;
    application/postscript                ps eps ai;
    application/rtf                       rtf;
    application/vnd.apple.mpegurl         m3u8;
    application/vnd.ms-excel              xls;
    application/vnd.ms-fontobject         eot;
    application/vnd.ms-powerpoint         ppt;
    application/vnd.wap.wmlc              wmlc;
    application/vnd.google-earth.kml+xml  kml;
    application/vnd.google-earth.kmz      kmz;
    application/x-7z-compressed           7z;
    application/x-cocoa                   cco;
    application/x-java-archive-diff       jardiff;
    application/x-java-jnlp-file          jnlp;
    application/x-makeself                run;
    application/x-perl                    pl pm;
    application/x-pilot                   prc pdb;
    application/x-rar-compressed          rar;
    application/x-redhat-package-manager  rpm;
    application/x-sea                     sea;
    application/x-shockwave-flash         swf;
    application/x-stuffit                 sit;
    application/x-tcl                     tcl tk;
    application/x-x509-ca-cert            der pem crt;
    application/x-xpinstall               xpi;
    application/xhtml+xml                 xhtml;
    application/xspf+xml                  xspf;
    application/zip                       zip;
    application/octet-stream              bin exe dll;
    application/octet-stream              deb;
    application/octet-stream              dmg;
    application/octet-stream              iso img;
    application/octet-stream              msi msp msm;
    application/vnd.openxmlformats-officedocument.wordprocessingml.document    docx;
    application/vnd.openxmlformats-officedocument.spreadsheetml.sheet          xlsx;
    application/vnd.openxmlformats-officedocument.presentationml.presentation  pptx;
    audio/midi                            mid midi kar;
    audio/mpeg                            mp3;
    audio/ogg                             ogg;
    audio/x-m4a                           m4a;
    audio/x-realaudio                     ra;
    video/3gpp                            3gpp 3gp;
    video/mp2t                            ts;
    video/mp4                             mp4;
    video/mpeg                            mpeg mpg;
    video/quicktime                       mov;
    video/webm                            webm;
    video/x-flv                           flv;
    video/x-m4v                           m4v;
    video/x-mng                           mng;
    video/x-ms-asf                        asx asf;
    video/x-ms-wmv                        wmv;
    video/x-msvideo                       avi;
# configuration file /etc/nginx/sites-enabled/default:
# https://www.nginx.com/resources/wiki/start/
# https://www.nginx.com/resources/wiki/start/topics/tutorials/config_pitfalls/
# https://wiki.debian.org/Nginx/DirectoryStructure
# In most cases, administrators will remove this file from sites-enabled/ and
# leave it as reference inside of sites-available where it will continue to be
# updated by the nginx packaging team.
# This file will automatically load configuration files provided by other
# applications, such as Drupal or Wordpress. These applications will be made
# available underneath a path with that package name, such as /drupal8.
        listen 80 default_server;
        # SSL configuration
        root /var/www/html;
        server_name _;
                try_files $uri $uri/ =404;
        #location ~ \.php$ {
        #       include snippets/fastcgi-php.conf;
        #       # With php-fpm (or other unix sockets):
        #       fastcgi_pass unix:/var/run/php/php7.0-fpm.sock;
        #       # With php-cgi (or other tcp sockets):
        #       fastcgi_pass 127.0.0.1:9000;
        # concurs with nginx's one
        #location ~ /\.ht {
        #       deny all;
#server {
#       listen 80;
#       listen [::]:80;
#       server_name example.com;
#       root /var/www/example.com;
#       index index.html;
#       location / {
#               try_files $uri $uri/ =404;
# configuration file /etc/nginx/sites-enabled/myportlink.cf:
        root /var/www/myportlink.cf/html;
        server_name myportlink.cf www.myportlink.cf;
    ssl_certificate /etc/letsencrypt/live/myportlink.cf/fullchain.pem; # managed by Certbot
    ssl_certificate_key /etc/letsencrypt/live/myportlink.cf/privkey.pem; # managed by Certbot
    if ($host = www.myportlink.cf) {
    } # managed by Certbot
    if ($host = myportlink.cf) {
        listen 80;
        listen [::]:80;
# configuration file /etc/letsencrypt/options-ssl-nginx.conf:
# this file.
ssl_session_cache shared:le_nginx_SSL:1m;
ssl_session_timeout 1440m;
ssl_ciphers "ECDHE-ECDSA-CHACHA20-POLY1305:ECDHE-RSA-CHACHA20-POLY1305:ECDHE-ECDSA-AES128-GCM-SHA256:ECDHE-RSA-AES128-GCM-SHA256:ECDHE-ECDSA-AES256-GCM-SHA384:ECDHE-RSA-AES256-GCM-SHA384:DHE-RSA-AES128-GCM-SHA256:DHE-RSA-AES256-GCM-SHA384:ECDHE-ECDSA-AES128-SHA256:ECDHE-RSA-AES128-SHA256:ECDHE-ECDSA-AES128-SHA:ECDHE-RSA-AES256-SHA384:ECDHE-RSA-AES128-SHA:ECDHE-ECDSA-AES256-SHA384:ECDHE-ECDSA-AES256-SHA:ECDHE-RSA-AES256-SHA:DHE-RSA-AES128-SHA256:DHE-RSA-AES128-SHA:DHE-RSA-AES256-SHA256:DHE-RSA-AES256-SHA:ECDHE-ECDSA-DES-CBC3-SHA:ECDHE-RSA-DES-CBC3-SHA:EDH-RSA-DES-CBC3-SHA:AES128-GCM-SHA256:AES256-GCM-SHA384:AES128-SHA256:AES256-SHA256:AES128-SHA:AES256-SHA:DES-CBC3-SHA:!DSS";
Now it works - https://myportlink.cf/ has a new Letsencrypt certificate :+1:
