My domain is: coderjobmarket.com
I ran this command: sudo certbot --nginx -d coderjobmarket.com -d www.coderjobmarket.com
http-01 challenge for coderjobmarket.com
http-01 challenge for www.coderjobmarket.com
Waiting for verification…
Failed authorization procedure. www.coderjobmarket.com (http-01): urn:ietf:params:acme:error:dns :: No valid IP addresses found for www.coderjobmarket.com
Domain: www.coderjobmarket.com
Type: None
Detail: No valid IP addresses found for www.coderjobmarket.com
My web server is (include version): nginx/1.14.0 (Ubuntu)
The operating system my web server runs on is (include version): Ubuntu 18.04.4
My hosting provider, if applicable, is: DigitalOcean
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): Yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): certbot 0.31.0
Other notes: My server is up and running with http: http://coderjobmarket.com/.
I read 5 threads that came up in the “Your topic is similar to…” box. My IP address is NOT within a private range as was the problem for one poster. One suggested that “certbot --nginx should be all you need to know” and the output for me of that command was:
certbot --nginx
The following error was encountered:
[Errno 13] Permission denied: ‘/var/log/letsencrypt/.certbot.lock’
Either run as root, or set --config-dir, --work-dir, and --logs-dir to writeable paths.
I don’t know if that’s helpful.
Here is a screenshot of my DNS records. I updated the CNAME record about 30 min ago. https://imgur.com/a/EUHrQcz
Anyone have a guess what my problem is? Will be checking the thread regularly for the next 2-3 hrs or so, then I have to leave for work.
