No valid IP addresses found for domain
I am hosting my website in the digital ocean server droplet. I have done it before, but now I need to obtain a certificate as well. If i host my application without configuring certificate I can access it both by ip and by www.forcecommit.com domain name. But trying to obtain a certificate and running this command:
sudo certbot --nginx -d forcecommit.com -d www.forcecommit.com
I get this error:
    http-01 challenge for forcecommit.com
    http-01 challenge for www.forcecommit.com
    Failed authorization procedure. forcecommit.com (http-01): urn:ietf:params:acme:error:connection :: The server could not connect to the client to verify the domain :: unknownHost :: No valid IP addresses found for forcecommit.com
   Domain: forcecommit.com
   Type:   connection
   Detail: unknownHost :: No valid IP addresses found for
   forcecommit.com
I am a little bit confused because I can ping that website and I get the response. What could be the problem?
Hi @Tomheza
your www has an ipv4 address, your non-www not ( checked with https://check-your-website.server-daten.de/?q=forcecommit.com ).
forcecommit.com A yes 1 0
AAAA yes
www.forcecommit.com A 104.248.24.36 yes 1 0
AAAA yes
So your non-www is invisible.
Create an A record in your dns settings with forcecommit.com and the same ip address.
You were right! I don’t know why I didn’t think it was necessary!
