I am extremely new with this so i am not sure how to access most of the things below. Sorry
My domain is:pianopianomalaysia.com
My hosting provider, if applicable, is: greengeeks
I can login to a root shell on my machine (yes or no, or I don't know): i dont know
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): cpanel
Have you seen this guide from your Webhoster?
GreenGeeks makes adding the Let's Encrypt SSL certificate easy. In this tutorial, I'll show you how to quickly add secuirty to your site for free.
Est. reading time: 3 minutes
Thanks! looking at it now.
Hi @Khang95
your domain has a valid ZeroSSL certificate.
So there is nothing to do.
You use cPanel, so you should check, if there is an integrated solution.
Just saw that too, your site is already secured with a TLS certificate. If you want to switch from ZeroSSL to Let's Encrypt, this has to be done through the cPanel, probably with aid of the guide I just posted above.
The ZeroSSL certificate can only be used for 3 times and i used all of them. The current one expiring in 4 days.
Not if you'd get the certificate through the ACME protocol.
system
Closed
May 31, 2021, 10:16am
8
