Learning what httpd and OS my web host uses
I want to switch from Zero|SSL to Let's Encrypt. I've no idea what httpd or OS my web host (nearlyfreespeech.net) uses. How to I proceed to get a certbot certificate?
My domain is: (www.)appl-ecosys.com
My hosting provider, if applicable, is: nearlyfreespeech.net
If I read Frequently Asked Questions - NearlyFreeSpeech.NET correctly, your hosting provider does not offer a VPS nor root access to the servers? So I'm puzzled by the answer you've given in this question to be honest.
Also, how would you get a ZeroSSL certificate to begin with? I'm not familiar with your situation, so can't answer how to change to Let's Encrypt, if that's even possible.
Hello @rshepard, welcome to the Let's Encrypt community. :slightly_smiling_face:
Using this tool SSL Server Test (Powered by Qualys SSL Labs) and looking at result towards the bottom you will find HTTP Requests if you expand that for your domain name SSL Server Test: appl-ecosys.com (Powered by Qualys SSL Labs) I see
When I do the same for your hosting provider SSL Server Test (Powered by Qualys SSL Labs) I see
Using https://sitereport.netcraft.com/ the results of
https://sitereport.netcraft.com/?url=https://appl-ecosys.com I see
So it seems the Operating System is FreeBSD and the web server is Apache.
On a UNIX (or even Linux) System the command uname -a will likely let one know what OS they or on.
1>uname -a
FreeBSD psg.com 13.1-RELEASE-p3 FreeBSD 13.1-RELEASE-p3 GENERIC amd64
I've had the ZeroSSL certificate for 86 days. Last Sunday I renewed it
(supposed to be for both with- and without www) but apparently it applied to
only one version. I asked them for clarification but saw no response. So now
I want to work with a group that's responsive.
Thanks,
Rich
Thank you. I assumed Apache was the server. When I log in to my NFS account
I don't know if uname -a works in my corner of their server.
Regards,
Rich
How? Please provide more details in your answers. With every answer you're about to give, you should ask yourself: "Could I provide MORE details?" and if the answer to that question is "yes", then you probably should. (Generic tip for when you're asking for help on forums on the internet.)
On the FreeSSL web site I clicked on my domain name, answered all the
questions, downloaded the .zip file containing the new ca_bundle.crt,
certificate.crt, and private.key. Using emacs I combined all three files
into a single buffer. Then I logged in my NFS account and uploaded the three
files using the TLS upload window.
Rich
I would not recommend using such sites to get a certificate, especially not if you're not using a CSR and you're not sure if the site has access to the generated private key (which would be BAD).
Please see the following FAQ regarding Let's Encrypt certificates on your hosting providers website: FAQ - NearlyFreeSpeech.NET
Osiris,
The certs from FreeSSL have worked just fine since last September. My reason
for changing is the unexplained issue they threw up when I renewed the
certs.
Thanks. I didn't see that one. Makes it very easy to replace the expiring
certs with ones from Let's Encrypt.
Regards,
Rich
Sure, the certs aren't the problem. But the lack of control over the private key and the fact it can't be automates are.
What unexplained issue would that be? You said suddenly the www subdomain (or the other) was gone? Isn't that an issue when filling out the info on the site when requesting a new cert?
I hope so! Apparently, it should also renew automatically!
No. That's now what I wrote. On Nov 6 I renewed the certs for what I thought
was both versions of the same domain name. Then on Nov 13 they sent a
message that I had a cert expiring this coming Sunday. When I logged in they
showed a renewed and an expiring site: both shown as appl-ecosys.com. So I
could not determine which flavor was supposed to be expiring and, in any
case, the one certificate was supposed to cover both flavors. A message I
sent asking for clarification was not answered. So tomorrow I'll let NFS
create and install a Let's Encrypt certificate.
Rich
