Need help trying to renew
Need help trying to renew the following for my domains
gitlab.spectrumbullpen.com
mail.spectrumbullpen.com
owncloud.spectrumbullpen.com
spectrumbullpen.com
www.spectrumbullpen.com
It’s is saying not secure and I can’t renewal these. Please help.
I have tried but is still having issues trying to renew these cert that are not secure, please help.
Hi, could you please answer the questions below? (They’re supposed to appear automatically when you create a new topic in the Help category, I guess they didn’t appear for you because you originally replied to an existing post instead of creating a new one).
Hi @dabeyonder
you have two active certificates, created 2018-10-26 and 2018-10-30.
https://transparencyreport.google.com/https/certificates?cert_search_auth=&cert_search_cert=&cert_search=include_expired:false;include_subdomains:false;domain:spectrumbullpen.com&lu=cert_search
But you don't use these.
Instead, your non-www and your www-version are using a self signed certificate.
http://spectrumbullpen.com/
74.96.71.163 200 0.367 H
http://www.spectrumbullpen.com/
74.96.71.163 200 0.340 H
https://spectrumbullpen.com/
74.96.71.163 200 6.260 N
Certificate error: RemoteCertificateNameMismatch, RemoteCertificateChainErrors
https://www.spectrumbullpen.com/
74.96.71.163 200 6.230 N
with the wrong name
CN=mail.spectrumbullpen.com, OU=Zimbra Collaboration Server (903)
30.10.2018
28.01.2019
mail.spectrumbullpen.com - 1 entry
How did you create these certificates 2018-10-26?
Hello it was created by cerbot or OpenSSL. Not sure what happen, however, how can I get the valid one installed and working, we had a turn over and haven’t had the signed SSL for our site in a few months. What steps are needed in order to correct this?
First please read the basics.
Then check your configuration if there is one of the ACME-clients.
If you use Certbot, check
https://certbot.eff.org/docs/using.html
Start witch
certbot certificates
as root.
