Certificate renew issue
My domain is: gitlab.moneypolo.zone
Attempting to renew cert (gitlab.moneypolo.zone) from /etc/letsencrypt/renewal/gitlab.moneypolo.zone.conf produced an unexpected error: Failed authorization procedure. gitlab.moneypolo.zone (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: The key authorization file from the server did not match this challenge [OYslH0QRomuEc_AB5XR3l0uKkXLzrUsHkh66pPEID-0.-OiumeD6NtXT3DHLsdSDEYi_3b_WIIDu44zi1kXW5SE] != [
Page not found
]. Skipping. All renewal attempts failed. The following certs could not be renewed: /etc/letsencrypt/live/gitlab.moneypolo.zone/fullchain.pem (failure)
The operating system my web server runs on is (include version): Centos 7 x64
Please show:
  1. the vhost file for “gitlab.moneypolo.zone” using 80
  2. any special handling for “/.well-known/acme-challenge” (if any)
  3. /var/log/letsencrypt/letsencrypt.log
  4. certbot --version
  5. certbot certificates
Hey Rudy,
add 1:
here is vhost .conf file located on rev proxy - mnps0024 is a webserver running LE + Gitlab.
<VirtualHost 192.168.3.253:80>
ServerName moneypolo.zone
ServerAlias www.moneypolo.zone
    AssignUserID www_moneypolo.zone vhosts
    ErrorLog  /var/log/httpd/moneypolo.zone-error.log
    CustomLog /var/log/httpd/moneypolo.zone-access.log combined
    HostnameLookups Off
    UseCanonicalName On
    AllowEncodedSlashes On
    ProxyRequests Off
    ProxyPreserveHost On
    <Location /var/www/public/letsencrypt>
            # Restrction
            # include /etc/httpd/IPrestriction/deny.conf
            # include /etc/httpd/IPrestriction/NAME.conf
            ProxyPass http://moneypolo.zone.mnps0024.mnp.local/
            ProxyPassReverse  http://moneypolo.zone.mnps0024.mnp.local/
    </Location>
add 2. No special handling so far
add 3. Here is a log from last renewal
FailedChallenges: Failed authorization procedure. gitlab.moneypolo.zone (http-01): urn:acme:error:unauthorized :: The client lacks sufficient authorization :: The key authorization file from the server did not match this challenge [OYslH0QRomuEc_AB5XR3l0uKkXLzrUsHkh66pPEID-0.-OiumeD6NtXT3DHLsdSDEYi_3b_WIIDu44zi1kXW5SE] != [
Page not found
2018-04-05 11:16:14,630:ERROR:certbot.renewal:All renewal attempts failed. The following certs could not be renewed:
2018-04-05 11:16:14,630:ERROR:certbot.renewal: /etc/letsencrypt/live/gitlab.moneypolo.zone/fullchain.pem (failure)
2018-04-05 11:16:14,631:DEBUG:certbot.log:Exiting abnormally:
File “/usr/bin/certbot”, line 9, in
load_entry_point(‘certbot==0.22.0’, ‘console_scripts’, ‘certbot’)()
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 1266, in main
File “/usr/lib/python2.7/site-packages/certbot/main.py”, line 1179, in renew
renewal.handle_renewal_request(config)
File “/usr/lib/python2.7/site-packages/certbot/renewal.py”, line 443, in handle_renewal_request
len(renew_failures), len(parse_failures)))
Error: 1 renew failure(s), 0 parse failure(s)
add 4 certbot version is 0.22.0
add 5 only for gitlab.moneypolo.zone
Thanks for any help!
Jiri
add 5
Found the following certs:
Certificate Name: gitlab.moneypolo.zone
Domains: gitlab.moneypolo.zone
Expiry Date: 2018-04-19 12:20:41+00:00 (VALID: 13 days)
Certificate Path: /etc/letsencrypt/live/gitlab.moneypolo.zone/fullchain.pem
Private Key Path: /etc/letsencrypt/live/gitlab.moneypolo.zone/privkey.pem
Where is
without that piece of the puzzle it is impossible to complete...
