Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. https://crt.sh/?q=example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
My domain is: www.beginnertrade.com ,www.addictionssigns.com , www.seinify.com
I ran this command:sslforfree
It produced this output: My website is still not going to HTTPS or Secure after a successful installation
The operating system my web server runs on is (include version): Linux
My hosting provider, if applicable, is: godaddy
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot): None of them, I just followed instructions from sslforfree.com
Hi @Hoosemon
what control panel do you use?
Is there a certificate upload and install form?
PS: Checked your first domain there is a different certificate ( https://check-your-website.server-daten.de/?q=beginnertrade.com ).
CN=*.prod.ams1.secureserver.net, OU=Domain Control Validated
03.04.2018
03.04.2020
expires in 374 days
*.prod.ams1.secureserver.net, prod.ams1.secureserver.net - 2 entries
So the name doesn't match.
And you have one wrong TXT entry:
TXT - Entries
Domainname
TXT Entry
Status
∑ Queries
∑ Timeout
beginnertrade.com
v=spf1 a mx ptr include:secureserver.net ~all
ok
1
0
ok
1
0
_acme-challenge.beginnertrade.com
f7vIfapNGxNaDItq1Z236JaN5Z3axjqxVjG0v_au-6A
looks good
1
0
_acme-challenge.www.beginnertrade.com
7H2hnllq5N89iw2hb1do91_TIGKRtq9dGLKfz1OneyM
looks good
1
0
_acme-challenge.beginnertrade.com.beginnertrade.com
perhaps wrong
1
0
The last entry is wrong.
If you use a control panel, your domain name is added.
So create only a new entry with
_acme-challenge
as name.
Hi JuergenAuer
I am using godaddy cpnal and there is an install form
[Should read the complete output]
You don't have a new certificate. But there are a lot of Letsencrypt certificates:
Last Certificates - Certificate Transparency Log Check (BETA)
CRT-Id
Issuer
not before
not after
Domain names
LE-Duplicate
next LE
1194252927
CN=Let's Encrypt Authority X3, O=Let's Encrypt, C=US
2019-02-11 12:24:36
2019-05-12 11:24:36
beginnertrade.com , www.beginnertrade.com
864638443
2018-10-15 14:25:15
2019-01-13 15:25:15
840524551
2018-10-09 09:58:32
2019-01-07 10:58:32
836853662
2018-10-08 15:08:39
2019-01-06 16:08:39
825444092
//certs.godaddy.com/repository/ , CN=Go Daddy Secure Certificate Authority - G2
2018-10-02 10:18:25
2020-10-02 10:18:25
addictionssigns.com , beginnertrade.com , biblenutrient.com , Domain Control Validated, newtechnol.com , seinify.com , www.newtechnol.com
Three created 2018-10, one 2019-02-11.
Is this the certificate you want to install? There is no newer certificate logged.
I just want my websites to be secure so I don’t mind about any certificate.
I just realise my former developer used a different procedure than the one I am using now.
So I am using the sslforfree.com procedure and not the install form
Hi JuergenAuer
There is an install form from Godaddy cpnal but I didn’t use it
I think my former delevopper used. I am using the sslforfree procedure
Can you advise me on how to get it from the installation form to the sslfofree please
Regards
You have to use both.
First sslforfree instead of an own ACME-client to create a certificate.
Then the upload form to install the certificate.
But if you create a new certificate, it must be visible via CT-Log. There is no new certificate -> the certificate creation didn't work.
Isn't there an integrated solution in your cPanel? Theck that first.
JuergenAuer:
What is CT-Log and integrated solution?
Hoosemon:
What is CT-Log
Most new certificates are logged in Certificate transparency logs. There are search engines to check that.
https://transparencyreport.google.com/https/certificates
The newest certificate - 2019-02-11. So you don't have created a newer certificate via sslforfree.
Hoosemon:
There is a cPanel addin, so it's enough that you activate that. But it's possible that your hoster didn't install that. If it is installed, you should use it. But then it may be impossible to use an external tool like sslforfree.
Hi JuergenAuer
Thank you for your help but I think I need to start reinstalling SSL from scratch in order for me to really understand what I am doing
I restart from scratch with sslforfree and I am receiving the following screenshot
which doesn’t allow me to move on.
The above screenshot it is received when I wanted to verify the upload downloaded file which was not successful.
Can you advise me about what to do please.
Regards
Create an exception - Advanced.
Or use my online tool with the complete url (without https://), then you can check the url.
Hoosemon:
Please fill out the fields below so we can help you better. Note: you must provide your domain name to get help. Domain names for issued certificates are all made public in Certificate Transparency logs (e.g. crt.sh | example.com ), so withholding your domain name here does not increase secrecy, but only makes it harder for us to provide help.
I'm using a control panel to manage my site (no, or provide the name and version of the control panel): yes
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you're using Certbot): None of them, I just followed instructions from sslforfree.com
Hi there
How the integrated solution looks like?
You have root access. Then you can use your own client, not Sslforfree.
Start there:
Then select a client - perhaps Certbot:
Last updated: Jul 22, 2023 | See all Documentation Let’s Encrypt uses the ACME protocol to verify that you control a given domain name and to issue you a certificate. To get a Let’s Encrypt certificate, you’ll need to choose a piece...
The only way to install SSL with Godaddy it is manually nothing work apart from that.
I have been reading that on this site a while.
If you have root access, you can do what you want.
Root access -> own client.
Shared hosting -> cPanel / Plesk or hoster support is required.
Hoosemon:
I have got root access but I don't really get the meaning << hoster support >> if you can bread it down for me, please
Regards
Could you send me any video tutorial link which can assist me in relation to the issue, please?
Regards
The hoster support is required if you have a shared hosting. So the hoster manages the webserver and the vHosts.
But if you are able to manage your own Apache and own vHosts (= if you have enough rights), then the hoster isn't relevant.
So Godaddy may not support Letsencrypt certificates if you have a shared hosting. But with an own vServer or Server - it's not relevant.
I've never checked a video.
to select the correct installation (or use certbot-auto)
then
https://certbot.eff.org/docs/using.html
