The key point in this is that it depends on your plan. If you have a VPS or dedicated server plan, then you are the administrator and you can use whatever software you want (for example, you could use our Certbot software, or you could install your own control panel with built-in Let’s Encrypt support, or use the Caddy server, or various other options).
If you have a shared hosting plan, then you are not the administrator and can potentially only use whatever the hosting provider has chosen. This case may require you to import a certificate via that host’s control panel interface, or switch to a different plan or hosting provider if your existing plan doesn’t allow third-party certificates.
Hey JuergenAuer
I have made some progress in relation to the ssl installation but when I reached almost the end of my installation I received an error message requesting me to disable my grammary software on my laptop and I did but the error message persists.
Can you advice me please.
The following message pups up on my screen
Please check “Service FAQ” and “How-To Videos” if you have questions.
1 Details
2 Verification
3 Certificate
NEXT
Verification results
Some domains have failed verification. Please study the list below and then click “Next” to try requesting new challenges for them. Note: the challenge values will be different.
Thanks a lot the idea is great but I can access my websites dashboards even though I went to database phpmyadmin it sent me back to not secure message so I am stuck.
Can you advise me please
