My lets encrypt ssl site not secure
My domain is: https://dammamgroupholdings.com/
I ran this command: tried visiting my page
It produced this output: it showed not secure when the certificate is on
My web server is (include version): dunno
The operating system my web server runs on is (include version): dunno
My hosting provider, if applicable, is: Dreamhost
pls how do i get it to be secure always.
Hi @tusirius
your certificate is valide and installed. But you have a lot of mixed content warnings, you load content via http, not https.
Use Chrome or FireFox, then CTRL + Shift + I, that opens the console.
There you see a lot of lines with warnings:
http://www.dammamgroupholdings.com/wp-content/uploads/2018/08/dammam-logo-transparent3-1.png
Change these to https.
I don't use WordPress. But perhaps there is an addin to do that automatic.
There's a setting (or two actually) to set the URL of the site. It includes http:// by default. Changing that to https:// should fix all the basic WordPress linking. But a malfunctioning plugin can always mess things up.
That may be one problem. There are links
http://dammamgroupholdings.com/wp-content/uploads/2018/08/dammam-logo-transparent3-1.png
and
so the same content is loaded via www and non-www.
Thank you all for your help… It was actually the mixed content problem. Used a plugin to correct them all because they were so many…thanks once again
