Maximum requests received for domain
My domain is:garysharp.com
I ran this command:Synology renew request from control panel
It produced this output:maximal (sic) certificate requests reached for this domain
My web server is (include version):Synology NAS DSM 6.2.2-24922 Update 4
The operating system my web server runs on is (include version): DSM 6.2.2-24922 Update 4
My hosting provider, if applicable, is:N/A
I can login to a root shell on my machine (yes or no, or I don’t know):Yes
I’m using a control panel to manage my site (no, or provide the name and version of the control panel):N/A
The version of my client is (e.g. output of certbot --version or certbot-auto --version if you’re using Certbot):Built into control panel for DSM
Hi @v8gaz
there is a blog, not a DSM.
And there is only one - very old and expired - Letsencrypt certificate ( https://check-your-website.server-daten.de/?q=garysharp.com#ct-logs ):
Let's Encrypt Authority X3 2018-06-04 2018-09-02 nas.garysharp.com
1 entries
There is a DSM - https://check-your-website.server-daten.de/?q=nas.garysharp.com
Looks like you have hitted the failed validation limit.
The basics are ok, port 80 is open and answers with the expected result http status 404 - Not Found checking a file in /.well-known/acme-challenge.
So only option (DSM is a closed world): Check, if there is an update of your DSM.
Blog is not hosted on the Synology, so you’re looking at the wrong thing.
Sorry, don’t know why I would have hot the failed validation limit, DSM is at the latest version. There is no LE cert installed right now, as it was expired and causing issues.
Any further ideas? And thanks for the quick response.
The check shows a (good looking) TXT entry.
May be that DSM uses dns validation.
But it's really a problem: The DSM Letsencrypt client is unknown.
So if there isn't a "great error" (wrong dns, port 80 closed), normally the DSM client should work. Sometimes there are problems with older versions, but if the version is up to date ...?
Isn't there a better protocol you can share?
