My domain is: disaster-lab.itsm3.com
I ran this command: ./letsencrypt-auto
Bootstrapping dependencies for Debian-based OSes…
Hit http ://mirror.ovh.net wheezy Release.gpg
Hit http ://security.debian.org wheezy/updates Release.gpg
Hit http ://nginx.org jessie Release.gpg
Hit http ://mirror.ovh.net wheezy/main amd64 Packages
Hit http ://http.debian.net wheezy-backports Release.gpg
Hit http ://mirror.ovh.net wheezy/main Translation-en
Hit http ://mirror.ovh.net wheezy/main Translation-es
Hit http: //nginx.org jessie/nginx Sources
Hit htt p://nginx.org jessie/nginx amd64 Packages
Hit http ://security.debian.org wheezy/updates/main amd64 Packages
Hit http ://security.debian.org wheezy/updates/main Translation-en
Ign http ://nginx.org jessie/nginx Translation-en
Ign http ://nginx.org jessie/nginx Translation-es
Hit http ://http.debian.net wheezy-backports/main amd64 Packages/DiffIndex
Hit http ://http.debian.net wheezy-backports/main Translation-en/DiffIndex
Hit htt ps://deb.nodesource.com wheezy Release.gpg
Hit htt ps://apt.dockerproject.org debian-wheezy Release.gpg
Hit ht tps://deb.nodesource.com wheezy Release
Hit ht tps://apt.dockerproject.org debian-wheezy Release
Hit ht tps://deb.nodesource.com wheezy/main Sources
Hit ht tps://deb.nodesource.com wheezy/main amd64 Packages
Hit ht tps://apt.dockerproject.org debian-wheezy/main amd64 Packages
Ign ht tps://apt.dockerproject.org debian-wheezy/main Translation-en
Ign ht tps://apt.dockerproject.org debian-wheezy/main Translation-es
Ign ht tps://deb.nodesource.com wheezy/main Translation-en
Ign ht tps://deb.nodesource.com wheezy/main Translation-es
Reading package lists… Done
W: Duplicate sources.list entry http://http.debian.net/debian/ wheezy-backports/main amd64 Packages (/var/lib/apt/lists/http.debian.net_debian_dists_wheezy-backports_main_binary-amd64_Packages)
W: You may want to run apt-get update to correct these problems
Building dependency tree
Reading state information… Done
ca-certificates is already the newest version.
dialog is already the newest version.
gcc is already the newest version.
libffi-dev is already the newest version.
python is already the newest version.
python-dev is already the newest version.
python-virtualenv is already the newest version.
libssl-dev is already the newest version.
augeas-lenses is already the newest version.
libaugeas0 is already the newest version.
0 upgraded, 0 newly installed, 0 to remove and 59 not upgraded.
Creating virtual environment…
Installing Python packages…
Had a problem while installing Python packages.
Collecting argparse==1.4.0 (from -r /tmp/tmp.B7CrgAW9ed/letsencrypt-auto-requirements.txt (line 6))
Downloading argparse-1.4.0-py2.py3-none-any.whl
Collecting pycparser==2.13 (from -r /tmp/tmp.B7CrgAW9ed/letsencrypt-auto-requirements.txt (line 12))
Downloading pycparser-2.13.tar.gz (299kB)
Collecting cffi==1.4.2 (from -r /tmp/tmp.B7CrgAW9ed/letsencrypt-auto-requirements.txt (line 16))
Downloading cffi-1.4.2.tar.gz (365kB)
Complete output from command python setup.py egg_info:
File “”, line 1, in
File “/tmp/pip-build-5mV8Ej/cffi/setup.py”, line 110, in
use_pkg_config()
File “/tmp/pip-build-5mV8Ej/cffi/setup.py”, line 73, in use_pkg_config
_ask_pkg_config(include_dirs, ‘–cflags-only-I’, ‘-I’, sysroot=True)
File “/tmp/pip-build-5mV8Ej/cffi/setup.py”, line 20, in _ask_pkg_config
stdout=subprocess.PIPE)
File “/usr/local/lib/python2.7/subprocess.py”, line 710, in init
errread, errwrite)
File “/usr/local/lib/python2.7/subprocess.py”, line 1335, in _execute_child
raise child_exception
OSError: [Errno 20] Not a directory
Command “python setup.py egg_info” failed with error code 1 in /tmp/pip-build-5mV8Ej/cffi
You are using pip version 8.0.3, however version 8.1.2 is available.
You should consider upgrading via the ‘pip install --upgrade pip’ command.
My web server is (include version): nginx/1.10.1 -> Apache/2.2.22 (Debian)
My hosting provider, if applicable, is: OVH
