Letsencrypt-auto keeps downloading dependencies
Hi there!
If I run the ./letsencrypt-auto command on my server,
it keeps trying to download dependencies.
For example I run:
./letsencrypt-auto certonly --standalone -d example.com -d www.example.com
It is going to download it’s dependencies, instead of giving me my public
and private keys.
Also in the archive and keys folder is empty (basically non existent).
What am I doing wrong?
Please post the full command output.
Full command output:
`Bootstrapping dependencies for RedHat-based OSes…
yum is /usr/bin/yum
Loaded plugins: fastestmirror, presto, priorities
Setting up Install Process
Loading mirror speeds from cached hostfile
  • base: mirror1.babylon.network
  • epel: epel.mirrors.ovh.net
  • extras: mirror0.babylon.network
  • rpmforge: www.mirrorservice.org
  • updates: centos.weezel.co.uk
    1565 packages excluded due to repository priority protections
    Package python-2.6.6-64.el6.x86_64 already installed and latest version
    Package python-devel-2.6.6-64.el6.x86_64 already installed and latest version
    Package python-virtualenv-1.10.1-1.el6.noarch already installed and latest version
    Nothing to do
    Package gcc-4.4.7-16.el6.x86_64 already installed and latest version
    Package dialog-1.1-9.20080819.1.el6.x86_64 already installed and latest version
    Package augeas-libs-1.0.0-10.el6.x86_64 already installed and latest version
    Package openssl-devel-1.0.1e-42.el6_7.2.x86_64 already installed and latest version
    Package libffi-devel-3.0.5-3.2.el6.x86_64 already installed and latest version
    Package redhat-rpm-config-9.0.3-44.el6.centos.noarch already installed and latest version
    Package ca-certificates-2015.2.4-65.0.1.el6_6.noarch already installed and latest version
    Nothing to do
    Nothing to do
    WARNING: Python 2.6 support is very experimental at present…
    if you would like to work on improving it, please ensure you have backups
    and then run this script again with the --debug flag!
This is the full command output.
This is your hint. Run the client with --debug.
That gives me the following line:
`IMPORTANT NOTES:
    Domain: uguardian.eu
    Type: urn:acme:error:connection
    Detail: Failed to connect to host for DVSNI challenge
For full response see:
http://pastebin.com/w4ZYBZik
Let’s Encrypt will attempt to open a HTTPS connection to your domain (uguardian.eu) to verify ownership. Make sure you don’t have any firewall rules or something similar that might block access to port 443 from the public internet.
Additionally, opening http://uguardian.eu/ results in a HTTP 400 error for me (which might or might not be related).
Thanks, I restarted the server and now it works.
It is currently offline because i’m installing the certificate.
Thanks for your help! :slight_smile:
