Issues with "Status"
Hello,
We are using a cPanel plugin to install SSL Certificates on all the domains on server. Since few days back, the SSL Certificate installation process goes well, but at the end it shows status message “Not Installed” and SSL Certificate don’t works on any domain.
I can’t attach a screen shot here.
I need your quick help guys and mods.
Thanks.
Hi @Hostlatte,
What’s the plugin you used?
Do you own the server?
Thank you
Does it look like this?
If so,
