There was a problem processing your request
- Error re-installing ssl certificate on domain
- lnncc.org.ly
- The certificate could not be installed on the domain “lnncc.org.ly”. Given “ip” (===.1.===.154) doesn’t match non-SSL vhost IP (===.1.===.200).
Hmm.
This points to an error/data inconsistency with the setup of your cPanel accont.
I think you need to speak to whoever admins the cPanel server.
When you speak to them, I think they should check the state of your account’s userdata files.
In /var/cpanel/userdata/{username}/lnncc.org.ly, the ip property should be the same as in /var/cpanel/userdata/{username}/lnncc.org.ly_SSL.
According to the error message, they are different. This would be a problem.
