Good Day,
Please my website has been inaccessible due to expired certificate https://aboutdevice.com. Only the homepage is accessible.
The problem is this
Error re-installing ssl certificate on domain
aboutdevice.com
The certificate could not be installed on the domain “aboutdevice.com”. “aboutdevice.com” already has a website on the IP address “96.30.0.56”, but you requested to add an SSL website for that domain onto the IP address “67.225.141.8”. A single domain may not have websites on more than one IP address.
I am using a shared hosting provider and please I will require your assistance to help resolve this problem.
I can access the website via cpanel. Thanks
Thanks ahaw021
I am using the apache webserver and I host my site at qservers.net
When I try to install it, it does not, it gives the error
I am doing it from my CPanel.
When I login into my Cpanel. I scrolled down to Security, I clicked on Lets Encrypt SSL. Then I clicked on Issue and then the error appear.
Please I attached some screenshots.
Even when I click on Reinstall above, the error still occur. Thanks
This doesn’t seem to be a let’s encrypt problem but rather a cPanel. issue.
I suggest you search their forums or post there to get the answer.
cPanel develop their own plugin so to solve the errors you need to get help from someone who understand how that plugin works (it could for example be a known error)
