Is there anyone for help
Hi Team,
I need help on SSL certificate renewal. I have renewal my Let's Encrypt SSL certificate in my wordpress but it still display not secure in edge. how can i fix it?
Welcome to the Let's Encrypt Community! :slightly_smiling_face:
We will need additional information (e.g. your domain name, screenshots/outputs of error(s)) to help you. I have several guesses as to the problem you face, but don't want to send you in a wrong direction.
When you opened this thread in the Help section, you should have been provided with a questionnaire. Maybe you didn't get it somehow (which is weird), or you've decided to delete it. In any case, all the answers to this questionnaire are required:
hi,griffin. thanks for your reply. i found the wrong is my certification just protect my domain not including my www.domain.com. how can i get the new certification to fix the error?
Hi @miecheal,
Try looking here User Guide — Certbot 2.11.0.dev0 documentation; the --expand command line option.
thanks for you reply,but it seem that the ssl certification not include it.is there i should instead a new one?
Hi @miecheal,
You might want to start here Getting Started - Let's Encrypt.
And the follow up with the rest of Documentation - Let's Encrypt
