Is it possible to use Lets Encrypt on Plesk without Certbot?
When i go for the lets get started page it tells me to install certbot. When i go on the Certbot Webpage it says that i do not need it, and that Plesk has it’s own Certificate Tool, which i already found on the Web-Interface. But how can i make it use Lets Encrypt, or is it even possible?
Because on the page with the supported providers i did not find Strato at all, and 1&1 is not planned to be supported.
Is there a way to get it running?
My web server is (include version): Plesk
The operating system my web server runs on is (include version): Ubuntu 14.04 LTS
My hosting provider, if applicable, is: Strato /1&1
I’m using a control panel to manage my site (no, or provide the name and version of the control panel): 12.0.18 Update #99
Thanks for your help!
plesk let’s encrypt extension
I am not trying to be rude or demeaning and i understand you have come here for help. However the fact that a forum is available for help doesn’t mean you can’t do a bit of research yourself
Andrei
