Https not working
My website seems not to be working with HTTPS. Yesterday was the 2 month anniversary of installing a Letsencrypt certificate. I ran the letsencrypt.exe and installed a fresh certificate but the website still does not work using HTTPS. It seems to be ok using HTTP…
www.sellerate.co.uk
Any thoughts on what might be the problem…?
Many thanks…
D
@Deeg
Is your bindings fine??
Is there any rewrite rules there??
What is the LE client you are using here?
I haven’t changed anything at all since it was working ok yesterday
The bindings seem to be ok - there is an https entry for port 443
The only “rewrite” thing I know of is a coded redirect in the default web page that redirects requests to the https version of the site url - if that is what you mean…?
I’m using “LetsEncypt1.9.4” on Windows 2016 - is that what you were asking ?
Thanks
I should also add that when I ran letsencrypt.exe, a certificate did seem to get created inside a newly created .well-known/acme-challenge directory so it looks like a new certificate was created - but not totally familiar with how this all works…?
check it is using newly created certs
Ah yes of course… thank you SO MUCH - i completely forgot about applying
the certificate…
it works again… thank you - very much appreciated
David
